    My mach 3 has decided to stop running on full screen.
    it worked fine and now it doesn't, I know that sounds like a cop out, but I never touched any settings, that im aware of.
    im hoping its something simple.
    thanks, paul
    Quote Originally Posted by paul_m View Post
    thanks, paul
    WTF.!! . . . . Water fall for a back ground.! . . . No wonder it's shrunk.!! Thought you where a bike Man why haven't we got some elbow scraping picture of Marquez or Rossi.! or better still the totty that holds the Broli. . .
    Try changing the screen settings in General Config.
    Well firstly, i have no excuse for the waterfall
    just tried those fixes but no dice, tbh they were already set from when you set it all up spot on dean.
    when it dropped, i did piss about with the properties when you right click on the exe file shortcut on the desktop.
    it works but all the text is falling all over itself and i think my eyes are sowing a little age wear and tare too.
    cheers mate.
  4. It happened to me once....
    just changing the screen resolution (Im talking about windows control panel, not mach) and then setting it back how it was did the trick.
    hope this helps
    Quote Originally Posted by gianluca_g View Post
    hope this helps
    He's sorted out now it was just a simple thing.
    If you minimise mach and then shut it down it remains minimised when re-opened. If you then expand the screen it stays minimised until you re-start Mach.
    Paul just wasn't re-starting Mach.!
  1. Mach3 table display
    By martin54 in forum Artsoft Mach (3 & 4)
    Last Post: 13-04-2013, 08:51 PM
  2. Question on Micro step resolution?
    By Ross77 in forum Artsoft Mach (3 & 4)
    Last Post: 12-02-2013, 04:08 AM
  3. Replies: 1
    Last Post: 29-05-2011, 08:15 PM
  4. Axis resolution advice
    By cweeks in forum Linear & Rotary Motion
    Last Post: 23-09-2010, 06:10 PM
  5. Display bezel
    By Robin Hewitt in forum General Electronics
    Last Post: 18-08-2009, 12:09 PM
