No, you haven't scared me away, just given me a lot to think about. hehe
Gunna have a long look at the builds, cheers.
Yea, I think I will get into CAD before I lift a single tool, but first, I definitely need to do far more research.
On a side note. I've taken a nema 23 stepper out of one of the photocopiers, its 2.8v and 3A and weighs about 1.12kg. The length without the shaft is 78mm and I think it has around 270 ounce-inch holding torque. Does this sound about right?
Will this stepper be O.K for an Ali gantry?Last edited by amd7000; 05-06-2015 at 06:04 PM. Reason: add
05-06-2015 #2
I wouldn't like to say for sure on electrical bits but comparing what you have with popular steppers for general CNC work:
Yours.....vs...Typical (e.g. SY60STH86-3008BF)
1.9 Nm..........3 Nm
2.8 V............5.46 V
78 mm..........88 mm
?.................3.2 mH (inductance - important value to get right)
3 A..............4.2 A
I have a stepper close to your spec on the Z and it works OK but I wouldn't use it on the X or Y (gantry) as it's a bit low on torque etc. M60STH88-3008DF is another popular choice with a similar spec. I'm giving you this info so you can build up your library of knowledge and have a look around - don't buy these sorts of bits yet until the design is ready!Last edited by routercnc; 05-06-2015 at 07:38 PM. Reason: spacing messed up when posted!
05-06-2015 #3
No. Not thinking of purchasing anything yet. Just thought I'd have a look at one of the steppers I have from the old photocopiers. Looks like I'll need to buy some then. Oh well. Thanks for the great information.
05-06-2015 #4
Steppers are one of the smallest expenses you are to deal with. Plus these steppers are possibly much more modern than the one in the photocopier. Plus the shaft may be is bigger and so on. Another thing worth noting is that most people drive them at 70V.
Here you will find them / the 3nm motors/ fairly priced.
05-06-2015 #5
Thanks for the link. Are they a decent company/reasonably priced?
Yea, its only a 7mm shaft on the stepper I have. What voltage could my stepper be run at?
06-06-2015 #6
I believe so.
I personally buy them from Zappautomation , cause at the time it happened that he responded faster my email. Plus he is active here at the forums. If i was in UK i would buy all from him. Now i buy a lot of stuff directly from China, due to the low euro/gbp and shipping costs involved of receiving materials here in Spain.
But if i learned one thing with the CNCs is that the main and most important thing you buy is the support, so many times saving a couple of $$ could result in weeks frustration and inability to produce during that time.
06-06-2015 #7
Thanks. Shall check them out too.
05-06-2015 #8
Thanks jess. I wouldn't trust myself with chemicals, played around with them too much when I was younger!!
Think I'm just gunna make one for wood and ali now. I just wanted to see if steel work was viable at my price point, it wasn't essential. It would have been handy to make a few bits for work, but it's no big deal.Last edited by amd7000; 05-06-2015 at 11:09 PM.
05-06-2015 #9
'Thin' makes me wonder if the requirement is for cutting out 2D/flat shapes, which might make a plasma cutter a viable option. It's often attractive because the lack of contact with the work piece means that the machine doesn't have to be nearly as rigid.
If there's a need for 'engraved' features on plasma cut work, then one option is to etch it with acid. If you've seen a brass and enamel sign, chances are it was produced this way. With very thin materials it's even possible to cut out shapes by etching from both sides. Etching is faster (specifically, it's great for area, but rubbish for depth) and cheaper than CNC but does involve some fairly nasty chemicals.
That CAD experience will pay off when you've got a CNC machine, and you need to prepare jobs for it.
If plasma cutting sounds like it might meet your requirements, BTW, then I think there's a few machine designs in the plasma table forum.
What 'decent' Milling machine?
By Chaz in forum Milling Machines, Builds & ConversionsReplies: 74Last Post: 21-06-2015, 04:32 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
eBay: Looks a decent little machine
By EddyCurrent in forum Items On eBay UKReplies: 13Last Post: 12-09-2013, 04:55 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
Already built my machine.. but some pics of work etc
By Yohudi in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-08-2007, 06:15 PM
