    looking at replacing my sem servo motor with something like this
    http://www.ebay.co.uk/itm/3KW-WATER-...item2a52124388
    as my machine has an ATC I need to get a pulley attached to the end of the spindle.
    the plan would be to mod and existing pulley rather than make a new one, so question is where do I find thread details of an ER20?
    many thanks
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by andy_con View Post
    many thanks
    Is this what you are looking for http://www.amazon.com/Dorian-Tool-ER.../dp/B00CB0Y7SI M25 x 1.5 Thread ..Clive
    perfect many thanks
  5. #4
    Andy Are you sure the spindle you linked to will do the job as they don't have any torque at low speeds say lower than about 3.5K rpm not like a servo ..Clive
  6. #5
    well...
    I have a denford triac, its got a sem MT30U4 servo motor -
    http://igor.chudov.com/projects/Brid...ata_Manual.pdf
    although a very good motor with lots of torque it only does 4000rpm, so my feed rates are really slow. but yes I can do a 2mm deep cut in ally with an 8mm cutter, or a 1mm deep cut in ally with a 20mm cutter without any trouble.
    what I was thinking was to get one of these Chinese spindles, swap the bearings out on my mill so they can handle the speed and do a 2:1 reduction. so id be looking at 12000rpm. so I would gain a bit more torque.
    I don't actually need to run the spindle at slow speeds, I use threadmills for tapping etc...
  7. #6
    Ok I was wondering if you needed position control on the spindle for the atc. That's not so easy on the spindle you linked too.. ..Clive
  8. #7
    nope don't need anything like that.
    ive never been able to find a torque curve for one of these Chinese spindle are there any? im assuming its peak torque comes at full power?
  9. #8
    I suppose it should be in the manual but who knows.
  10. #9
    hahaha funny... ;-)
    Chinese manuals don't have any information you need, just the information you don't need
  11. #10
    hahaha funny... ;-)
    Being up north you have to have a sense of humour If jonathan was on line he would most likely know that sort of info. Nice spindle though.
  1. Denford Triac VMC
    By fidia in forum Milling Machines, Builds & Conversions
    Last Post: 19-08-2016, 08:18 AM
  2. FOR SALE: ER20 DIY Spindle Parts
    By Mad Professor in forum Items For Sale
    Last Post: 03-11-2012, 06:51 PM
  3. Conversion of ER16 spindle to ER20
    Last Post: 14-07-2012, 05:19 PM
  4. Chinese vfd/spindle question
    By Shinobiwan in forum Tool & Tooling Technology
    Last Post: 02-03-2012, 02:02 AM
  5. Denford Triac Spindle Fault
    By Sam_Smith in forum Denford Mills
    Last Post: 04-05-2011, 11:07 PM
