  1. #13
    Actually ignore my last post...if your relay board is the same as mine, from recollection the 5V from your driving IO pin, doesn't energize the relay directly, but does so via a tranny/fet. Are you supplying the relay board with a separate 5V supply?
  1. CSMIO-IP/S Driving Relays directly
    By cropwell in forum CS-Lab (CSMIO)
    Last Post: 02-01-2017, 01:40 AM
  2. Using current as cutting force indicator?
    By mitchejc in forum General Electronics
    Last Post: 13-01-2015, 05:09 AM
  3. question about relays
    By frankman in forum General Electronics
    Last Post: 23-01-2012, 07:47 AM
  4. Current Set Resistors.
    By NzOldun in forum Motor Drivers & Controllers
    Last Post: 20-06-2011, 08:38 AM
  5. G540 Current set resistors
    By blueseidboy in forum Motor Drivers & Controllers
    Last Post: 23-08-2010, 02:21 PM
