Thread: 8 x 4 build
    D.C.'s Avatar
    Have you a read through this build log? Lots of renderings at the start and photos of the frame later on that might help.
    http://www.mycncuk.com/threads/6619-...2060#post52060
    Quote Originally Posted by reefy86 View Post
    do you mean ball screws? if so then yes both sides :) using nema 34 motors and servo drivers.
    cheers
    ash
    Ok then have factored in the whip of the screws at that length etc.
    hi clive, what do you mean have factored in the whip?
    cheers
    cheers
    Ball screws have a critical speed that you can reach before they start to whip I am not an expert on this but I would have thought that if you are using screws that long you might need rotating ball nuts. Do a search on here there has been plenty of talk about it.
  5. #15
    i used rotating nuts, on my 8x4 build because of the whip effect Clive mentions.
    skip to about 1:15
    http://www.mycncuk.com/threads/8242-...t=wall+mounted
  6. #16
    thanks guys i will take a look :)
  7. #17
    i want to hide my z axis stepper motor rather then having it stuck in the air so it requires a belt and pulley, is there a requirement to which i should aim for? more teeth the better or the opposite?
    cheers
    ash
  8. #18
    i recommend to brace the legs with the diagonals , not the way it is now, there is no force pushing on the braces on that orientation
  9. #19
    think this maybe my final design on the frame, what do you think?
    cheers
    ash
Name:	bed frame 4.1.jpg
ID:	15928   Click image for larger version.
Name:	bed frame 4.2.jpg
ID:	15929   Click image for larger version.
Name:	bed frame 4.jpg
  10. #20
    I would suggest you don't need the flat bar as it's not likely to add anything, where you've got the angled sections on the "feet/legs" of the frame, move those up into the rectangular spaces or add some there, they will serve you much better.
    .Me
  1. BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
    By grain_r in forum DIY Router Build Logs
    Last Post: 27-01-2023, 06:47 PM
  2. BUILD LOG: New Build - For Your Amusement - MK-2 build
