Thread: Easy Servo Drive?
14-09-2015 #11
Jazz Thanks so much for the kind offer! Can you link to something that explains what an external motion controller does differently than my current parallel port to break-out-board setup? Looking at the smooth stepper site it basically looks like a USB to parallel port but I assume it must be more than that because such a thing is very cheap and small. Would I still use my break-out-board?
If it means anything I get a 'Time In Int.' on Mach3 sitting at about 4 when idle and jumping between 4 and 11 when running. Does that occasional jump mean something bad?
https://youtu.be/0hVQXoq_eqI
DeagonFly, the laptop is dedicated to CNC and runs WinXP. I chose it because it has a built in parallel port which I assumed would be better than a USB or PCMCIA adaptor.
Build Log: Servo Drive and VFD with vector control
By Jonathan in forum Electronic Project BuildingReplies: 17Last Post: 05-04-2015, 07:58 PM -
eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
By dazza in forum Items On eBay UKReplies: 0Last Post: 29-01-2015, 08:55 AM -
FOR SALE: 160v dc servo drive
By dazza in forum Items For SaleReplies: 0Last Post: 27-01-2015, 03:16 PM -
Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
By george uk in forum Motor Drivers & ControllersReplies: 20Last Post: 23-06-2014, 08:38 PM -
Servo drive problems
By Tomnewry in forum Motor Drivers & ControllersReplies: 15Last Post: 27-03-2013, 11:30 PM
