Thread: 3 Axis CNC router
Hi Jazz,
So your small design above doesn't have a back piece on the Z axis assembly, but has side panels to give strength to the joints?
Looking again at rail location, would one rail on the bottom and one on the front be a good combination? Like this machine:
19-09-2015 #2
Yes doesn't have back piece because it add's no strength just weight. The Panels you refer to are not for strength, thou they do slightly add some. It's purely a Cover to protect the whole Z axis assembly from dust and crap. It's very affective and neat.
The 90Deg joints are perfectly strong enough for any type of work upto and including machining aluminium.!
Regards rail location then it's a personal choice and also partly machine design related. Me personally I prefer to keep things stout and compact and gain maximum real estate. But if you need clearence for ballscrews etc at the front then putting rails on the front allows this and keeps it stiff. Each way has it's own Plus's & minus's. Both work equally well so take your pick.!!Last edited by JAZZCNC; 19-09-2015 at 11:06 PM.
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
