Thread: One ring to rule them all?
03-11-2015 #4
Thanks guys,
I've been going over some of the numbers, I'm thinking the torsional load on the gantry is the weak point.
Using this calculator
http://www.kennametal.com/en/resourc...and-power.html a 16mm 4 flute endmill in steel with recommended chip load feeds speeds I get a tangential load of 1000n / 100kg.
Assuming a Z travel of 1m, 1000nm torque on gantry.
Using HIWIN HG25 linear rails http://cnc4you.co.uk/resources/Hiwin%20General.pdf
basic dynamic load rating (lowest rating)
26kn / 2600kg. At a separation distance of 300mm and 1m Z that would be 780kg or 7800nm (but there is 2 of them so this times two really). Clearly the linear guides are adequate.
So then there is the torsional deflection of the gantry beam.
θ = TL/GJ
θ radians deflected
T torque = 1000nm
L length = 1m
G Shear modulus = 80 steel
T Torsional Constant = 180 m4
200x100x8 box
section http://www.roymech.co.uk/Useful_Tabl...ns/RHS_cf.html
= 0.006944444 radians / or 0.12114 mm at 1m Z travel
This is the calculation of a 1m gantry supported at only one end, not sure of the calculation for a torque at the mid-point. I assume it would be less. I assume it would be at least halved with 2 box sections welded together.
So I'm assuming it would be in the range of 0.05 which is acceptable I feel. It most likely wouldn't be enough to matter in most cases and even if it did you could work around it.
What do you think? Have I made a math error?
Thanks Rufe0
Nitrile O-ring belt drive - suggested stretch percentage..?
By Wal in forum Linear & Rotary MotionReplies: 23Last Post: 13-05-2014, 11:49 PM -
Domestic ring main wiring
By mekanik in forum General ElectronicsReplies: 1Last Post: 15-10-2013, 05:50 PM -
Simple O-ring calculator.
By jcb121 in forum General ComputingReplies: 4Last Post: 26-07-2013, 09:00 PM -
how to measure a ring for cnc.
By crimsonred in forum Probing, Digitizing & ScaningReplies: 4Last Post: 27-09-2010, 02:47 PM -
Scrool jaw ring for hydraulic soft jaws.
By Pmac in forum Tool & Tooling TechnologyReplies: 4Last Post: 28-01-2010, 07:55 PM
