    Quote Originally Posted by Davo242 View Post
    ok i attached the motors to the cnc and still no change. i aslo have change the ms to 1/4 and 80. still nothing.
    where can i find the step low active setting.
    As a matter of interest what Voltage is your power supply to the drives?
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    I was just about to ask the same. Is the Voltage at the right level and 'clean'?
    That said, it does feel like a Mach 3 config issue, look at the end of the vid, the DRO numbers look to pause and then unpause ...
    its getting 24.4v
    Chaz's Avatar
    its getting 24.4v
    Is that what the drives need? Sounds low to me but could be correct, not looked at any specs etc
    what should the normal voltage be ? is there any way i could send u the maual for the drivers?
    Chaz's Avatar
    There isnt 'normal'. I tend to see 50-80V usually. What does teh specification of the drivers say?
    Introduction
    The TB1H is a high performance microstepping driver based on the latest original TOSHIBA high-efficiency TB6600HG IC. The TB6600HG adopts PWM chopper-type single-chip bipolar sinusoidal to ensure the low vibration and high efficiency. Moreover, the brand new design with BiCD0.13 (50V) process technology on the chipset also ensures maximum 5.0A output current and 50V output withstand voltage. Consequently, as long as the current range of the stepper motor is within 0.2-5 amps, all the 2 Phase or 4 Phase of Nema17, Nema23, Nema24 and Nema34 stepper motors will work perfectly with this new-type TB6600HG Stepper Driver.
    Features
    High performance, cost-effective
    Automatic idle-current reduction
    Supply voltage up to 50V DC
    Output current up to 5.0A
    Suitable for 2-phase and 4-phase motors
    High speed optoelectronic isolation signal input
    Overload, overcurrent, overheat, overvoltage and undervoltage protection
    Single-chip PWM bipolar sinusoidal chopper ensures low vibration and high efficiency
    1, 2, 4 (New Mode), 8, 16 adjustable microstep control, motors run more precisely and smoothly
    Equipped with the 3rd generation of breakout board, display panel and control pad to control the motor manually.
    Cooling Aluminium Box Design for Cooling, and protect the driver board from being damaged by dirt, dust or other liquids.
    Applications
    Suitable for a wide range of stepping motors, from NEMA size 17 to 34. It can be used in various kinds of machines, such as X-Y tables, labeling machines, laser cutters, engraving machines, pick-place devices, and so on. Particularly adapt to the applications desired with low noise, low heating, and high speed performance.Both of regulated and unregulated DC power supplies can be used to supply TB1H stepper driver. However, unregulated power
    supplies are preferred due to their ability to withstand current surge. If regulated power supplies (such as most off switching
    supplies.) are indeed used, it is important to have large current output rating to avoid problems like current clamp, for example
    using 4A supply for 3A motor-driver operation. On the other hand, if unregulated supply is used, one may use a power supply of
    lower current rating than that of motor (typically 50%~70% of motor current). The reason is that the driver draws current from
    the power supply capacitor of the unregulated supply only during the ON duration of the PWM cycle, but not during the OFF
    duration. Therefore, the average current withdrawn from power supply is considerably less than motor current. For example, two
    3A motors can be well supplied by one power supply of 4A rating. Although the unregulated power supplies are preferred,
    considering the cost, the cheap and easy-to-use regulated switching supplies in the market is also a good choice for the TB1H
    stepper driver and motors, as long as the total output current of the regulated switching supplies is larger than the motor’s total
    rated current. Anyway, if users don’t know how to select the suitable power supplies for the TB1H stepper driver and motors,
    please feel free to contact with us for assistances.
    II. Selecting Supply Voltage
    The TB1H stepper driver can actually operate within 12-50V(Peak Voltage) DC for different motors. Higher supply voltage can
    increase motor torque at higher speeds, thus helpful for avoiding losing steps. However, higher voltage may cause more motor
    vibration at lower speed, and it may also cause motor overheat and drive damage. Therefore, it is suggested to choose 12-24V DC
    i was looking threw some set up videos on youtube and it was showing how to test the driver with mach3, my test showed that mine was pulsing to slow. but when i tried to up the kh it never changed. could this be a slow computer problem?
  1. stepper motors
    By reefy86 in forum Gantry/Router Machines & Building
    Last Post: 06-09-2015, 12:54 PM
  2. Replies: 6
    Last Post: 27-05-2012, 06:06 AM
  3. Help with Stepper Motors
    By Scott in forum Stepper & Servo Motors
    Last Post: 04-04-2010, 02:35 PM
  4. rs stepper motors
    By chaz@2b in forum Stepper & Servo Motors
    Last Post: 06-08-2009, 11:05 PM
