  1. #21
    [ATTACH=CONFIG]It's easy see pic. Here we are using the Relay on the Spindle to Control ON/OFF. (Top 2 wires)
    The bottom 2 wires are 0-10V for speed control.
    You will need to change some parameters in the VFD. These tell the VFD it's being controlled from external source. (Won't be able to control from VFD front panel unless set back to 0)
    PD001 = 1
    PD002 = 1
    Now just set Mach3 up according to manual regards Spindle speed and Relay control.
    Edit: I loaded wrong Pic up first time, should have gone to V1 not A1. (Thanks for spotting Rob)
    Thank you SO much ! I will be connecting these four wires tomorrow and post pictures of the finished control cabinet :) ! Can't wait :D The machine's almost ready :D
    I was also wondering what the 10-24V inputs of the BOB (between top 2 and bottom 2 pins you connected to the VFD) are used for ?
  1. Which wiring diagram software do you use ?
    By eurikain in forum Computer Software
    Last Post: 11-10-2015, 02:48 PM
  2. VFD Wiring Diagram
    By Tomnewry in forum General Electronics
    Last Post: 14-10-2013, 06:46 PM
  3. Wiring diagram for 4x4 cnc router
    By Danielroyal25 in forum General Electronics
    Last Post: 19-07-2013, 11:14 PM
  4. NEW MEMBER: Hi, Looking for a wiring diagram, Melbourne
    By Sampop in forum New Member Introductions
    Last Post: 28-10-2010, 11:18 AM
  5. Hardinge hc chucker wiring diagram
    By hrdg4me in forum General Electronics
    Last Post: 16-12-2009, 03:57 PM
