yes but where can you buy it?
23-03-2016 #2
23-03-2016 #3
ok, thanks, I gather we are talking mostly paraffin in the mix - 10% oil or more?
24-03-2016 #4
I have one of those misters as in post #1, I am going to try it with a solenoid valve to pulse the air, using an Arduino to control it via a relay, so I can experiment with pulse and space times. It won't be until I have built my machine though, later this year.
24-03-2016 #5
That would likely work ok, but set the jet in the nozzle so that it makes droplets not mist, will need to pressurise the fluid container as well.
25-03-2016 #6
Well I made a Fog-Buster style unit and it does a pretty god job of fogging the shop up :(
What do we need to do to it to stop it fogging and start it splattering?
I'm using a 0.6 mig tip, maybe too small? might run a drill up it and see what happens, It also only works wit two pressure regulators - the fluid must be set higher than the air blast.
25-03-2016 #7
Coolant, I am not sure which one to go with.
By suesi34e in forum Swarf & Chip ManagementReplies: 23Last Post: 17-10-2015, 07:13 PM -
My Coolant System
By Tenson in forum Swarf & Chip ManagementReplies: 6Last Post: 08-04-2013, 01:59 PM -
Washing Machine Pump Coolant System
By Lee Roberts in forum Electronic Project BuildingReplies: 7Last Post: 05-05-2012, 01:30 AM -
coolant
By luke11cnc in forum Machine DiscussionReplies: 4Last Post: 11-02-2012, 01:17 PM -
Potential project opportunity
By irving2008 in forum General DiscussionReplies: 2Last Post: 11-09-2010, 12:44 AM
