Well I made a Fog-Buster style unit and it does a pretty god job of fogging the shop up :(
What do we need to do to it to stop it fogging and start it splattering?
I'm using a 0.6 mig tip, maybe too small? might run a drill up it and see what happens, It also only works wit two pressure regulators - the fluid must be set higher than the air blast.
25-03-2016 #2
25-03-2016 #3
Different shape but essentially the same, I followed dimensions I found online, 2.2mm through-bore with 1mm fluid bore, I have a flow control on the fluid inlet, one regulator on the fluid feed and one on the air feed.
I think the nozzle is too small at 0.6mm, I will drill out to 1mm and try that - it should reduce air velocity and increase droplet size hopefully.
Edit
Just been looking at the Original Fog-Buster web site an they have no nozzle at all - just a plain tube so I might just cut the nozzle off and try that.Last edited by Davek0974; 25-03-2016 at 08:07 PM.
25-03-2016 #4
Isn't a mist spray of paraffin a ghastly accident looking for ignition?
Not saying you shouldn't, but I nearly lost my eyebrows spark eroding with paraffin electrolyte when I broke through in to a cavity.
Coolant, I am not sure which one to go with.
By suesi34e in forum Swarf & Chip ManagementReplies: 23Last Post: 17-10-2015, 07:13 PM -
My Coolant System
By Tenson in forum Swarf & Chip ManagementReplies: 6Last Post: 08-04-2013, 01:59 PM -
Washing Machine Pump Coolant System
By Lee Roberts in forum Electronic Project BuildingReplies: 7Last Post: 05-05-2012, 01:30 AM -
coolant
By luke11cnc in forum Machine DiscussionReplies: 4Last Post: 11-02-2012, 01:17 PM -
Potential project opportunity
By irving2008 in forum General DiscussionReplies: 2Last Post: 11-09-2010, 12:44 AM
