Thread: 6040 Spindle Coolant
05-04-2016 #1
Hello All,
I am completely new to CNC (my background is enterprise network management).
So, please be patient and gentle!
Here goes...
I just setup a 6040z machine, and did not want to put water into the spindle; someone else advised me to not do this.
So, I had some RV antifreeze solution and decided to run that through the spindle. It says it is non-corrosive.
Will the RV coolant do the trick without destroying the spindle?
(or)
Is there something else that I should be using, instead?
Thanks in advance...
Mark
05-04-2016 #2
I dont know what you mean by Rv antifreeze, but i run with car antifreeze, the strongest one pink in color up to -45C, undiluted from a couple of years and o problem. The Ethylene glycol it contains definitely cools better than pure water. Just remember not to put tap water into it if you dilute or run it on water,. use only distilled water.
We are talking about water cooled spindle right? Not an air cooled one i hope
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
05-04-2016 #3
What's the problem with tap water? Not that I've, errrr, done that or anything.
05-04-2016 #4
05-04-2016 #5
Tap water will inevitably have some mineral content and the minerals can be deposited on internal surfaces making heat transfer less efficient.
The Following User Says Thank You to magicniner For This Useful Post:
05-04-2016 #6
RV antifreeze is fine. In fact it is better than deioinised water on its own.
https://emvioeng.com
The Following User Says Thank You to komatias For This Useful Post:
08-04-2016 #7
09-04-2016 #8
The Following User Says Thank You to cropwell For This Useful Post:
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Coolant Pump
By Chaz in forum Swarf & Chip ManagementReplies: 23Last Post: 25-01-2016, 10:27 AM -
Coolant, I am not sure which one to go with.
By suesi34e in forum Swarf & Chip ManagementReplies: 23Last Post: 17-10-2015, 07:13 PM -
coolant
By luke11cnc in forum Machine DiscussionReplies: 4Last Post: 11-02-2012, 01:17 PM -
What coolant to use??
By don_jarr in forum General DiscussionReplies: 13Last Post: 05-11-2011, 03:12 PM
