Page 16 of 23 FirstFirst ... 61415161718 ... LastLast
  1. #151
    I think the first post of this thread needs to be updated with the following information:
    • If you're controlling the spindle speed from Mach3, you also need to:
      - set PD002 to 1. It might be done automatically, but it's worth checking.
      - change the jumper on the right side of the VFD control terminal to VI instead of VR
    • Set PD070 according to your BOB's specifications. It is the input voltage that the VFD receives on its control terminal. My BOB sends 0-10V, so I had to change the setting. Check the manual for more information.
    Cheers,
    G.
  2. #152
    Jazz previously suggested upgrading the coolant fittings on these spindles for some push fit/lock type, I like this idea so here is a link to some on eBay:
    High Pressure Metal Push-in Fittings for Air or Central Lubrication Systems Tube
    http://m.ebay.co.uk/itm/271182576634
    You want the M8x1 fine thread option for the correct fit, dose/maybe the OP wants to add this info to the first post.
    EDIT: Better prices and info can be found here:
    http://www.mycncuk.com/threads/9452-...g?goto=newpost
    .Me
    OK, guys so before I start plugging in wires is this diagram right?
    I want to be able to start the spindle and control the RPM from the EDINGCNC Software
    Link to the board manual in case needed http://www.edingcnc.com/upload/files/cpu5a_flyer_tech.pdf
  4. #154
    lucan07's Avatar
    Lives in northampton, United Kingdom. Last Activity: 19 Hours Ago Has been a member for 9-10 years. Has a total post count of 257. Received thanks 24 times, giving thanks to others 6 times.
    Don't know if its just me but clicking on your diagram to view it locks my system, could be links blocked on my sysem for security reasons but only image on site I've tried to view that does this.
  5. #155
    Not quite sure what it should be, but I don't think that there should be any connection to the "spindle sensor" pin. That's for sensing spindle position on a lathe for threading purposes, nothing to do with router spindle. I think you've wired the VFD so that it is forward-running only (no reverse, which seems reasonable) but there's no spindle start/stop signal from the board to VFD. I don't know how the Eding board and software handle for/rev or start/stop - I'm going through the same wiring design process with CSMIO/Mach3 and VFD which is a better-documented route.
  6. #156
    Yeah seems a bit of a headache
  7. #157
    Here is how I have it wired:
    I don't have the same board as you but it'll give you an idea. Red / black controls the speed, purple / black controls the start/stop :)
  8. The Following User Says Thank You to eurikain For This Useful Post:
  9. #158
    Quote Originally Posted by eurikain View Post
    What board is that so I can get a little more info pal?
  10. #159
    As far as I can see, the Eding manual says that you use the "tool" output pin as a start/stop signal to the VFD but I haven't worked out for myself which VFD pin it goes to yet - still reading that manual!
  11. #160
    You're a gent! Thanks for taking the time!
    I used to have the spindle running off the software but only start/stop I could control the RPM. The start stop was in pin 1 and pin 17
  1. Chinese Spindles
    By Ricardoco in forum Generic Chinese Spindles
    Last Post: 05-12-2016, 12:16 AM
  2. Info on Chinese suppliers, their reliability and reputation
    By Want2build1 in forum Marketplace Discussion
    Last Post: 07-12-2013, 09:37 PM
  3. NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
    By Tomcat in forum New Member Introductions
    Last Post: 03-03-2013, 01:43 PM
  4. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 08:58 PM
  5. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 06:20 PM
