Page 4 of 6 FirstFirst ... 23456 LastLast
  1. #31
    thanks guys you have all been a huge help and have saved me a lot of time money and headache i thank you all for the great advice.
  2. #32
    By the way is there basic software that will allow me to do different font letters and different shapes.
  3. #33
    Quote Originally Posted by theceo View Post
    yes, get inkscape or adobe illustrator or corel draw, create vector graphics, export as DXF, then import into the software that comes with the laser. You can do very basic stuff on the lasers software too, I use it for quick jobs all the time
    https://emvioeng.com
  4. #34
    Don't use a lot of the other software mentioned but inkscape has many plugins that tend to be missed, but I use inkscape to generate G-code directly for my engraver/cutter powerful program once you get to know your way around and its free.
  5. #35
    thanks again guys
  6. #36
    Hello guys got my machine and will be putting it together over the Holiday weekend, I am excited to try it out and see what it can do, I will let you guys know how everything goes thanks again.
  7. #37
    Pics or it never happend!
  8. #38
    My CNC machine the journey begins Click image for larger version.
  9. #39
    Now I need to know how to use inkskape to design with my machine
  10. #40
    Remember to treat temperature of coolant as essential if not fitterd fit a thermal cut out to coolant system, and use minimum required power to maximise tube life, 30 minute running hot or over driven can kill the tubes. Also buy the laser quality MDF and PLY as they cut easilly compared to standard products also maintaining tube life.
  1. What 'decent' Milling machine?
    By Chaz in forum Milling Machines, Builds & Conversions
    Last Post: 21-06-2015, 04:32 PM
  2. Will steel angle work for a decent machine?
    By amd7000 in forum Gantry/Router Machines & Building
    Last Post: 06-06-2015, 12:47 PM
  3. eBay: Looks a decent little machine
    By EddyCurrent in forum Items On eBay UK
    Last Post: 12-09-2013, 04:55 PM
  4. A decent little (PCB miilling) Chinese machine...
    Last Post: 18-06-2013, 06:59 PM
  5. BUILD LOG: small mill for machining steel. Max spend £500 including computer
    By Andrew Wilding in forum DIY Mill Build Logs
    Last Post: 20-07-2012, 03:46 PM
