    Hi
    Looking for advice on the best beginners / entry level Jewellery engraver.
    I've seen lots of YouTube videos of what seem expensive machines. Seen lot of ads for cheap Chinese machines. For clarity, I've nothing against Chinese things as I have a friend there and we do import other Chinese products.
    I want to do jewellery and wedding gifts. Cufflinks, hip flasks, pens, bangles wedding favours, Cufflink boxes etc.
    Not sure about round things like tankards or rings. Will depend on that extra costs.
    I I guess it would be good to know which are the Cheaper machines I could look at versus which are the expensive ones I could wait to buy or but used ?
    I knows there's no signal correct answer so very happy to look through all machines you recommend.
    Many thans
    Frank
    Have a friend with a jewellry business and almost everything they do is either free hand or on a manual copy machine, only CNC they use is their fibre laser which was not an entry level item.
  3. The Following User Says Thank You to lucan07 For This Useful Post:
    Hi lucan07
    Thanks for the reply.
    By manual copy do you mean like a pantograph machine ?
    ive been offered a Gravograph IM3 for a real good price.
    I'd like to see the variety of engraving that it can achieve first but would get it.
    I know it does scratch engraving but wonder if it can do a slightly deeper engrave? Also, the range of things I could engrave.
    Any my help gratefully received.
    Frank
  5. #4
    Yes that the type of thing they use they have circular disks of fonts etc they can load and dial in whatever is required or copy various templates scaling as required, and even work inside rings with one of them of them. Search YouTube I would imagine plenty of vid's showing capabilities of the machine on offer, but I would imagine some of the font templates etc are expensive to buy.
    The problem with CNC is the set up time they can do the jobs freehand quicker than plugging it in.
  6. #5
    I have an IM3, it has a motor and does excellent deep rotary cut/milled engraving, the IM3 is a current model, £450 would be a good price with one font.
    I have 4 or 5 Gravograph fonts which amount to more investment than the machine itself.
    The IM3 is a 2D pantograph, any cut engraving is fixed depth, using an adjustable nose on the spindle, if you have a spindle depth guide with a freely moving spherical nose it's possible to engrave fixed depth on uneven and curved surfaces.
    My move to CNC was driven by the need to engrave fonts, symbols and graphics not available in off the shelf font template sets, I used the pantograph to generate custom templates based on laser printed A4 graphics glued to card and hand cut with reduction to create master templates.
    For engraving jobs I'm now using a small CNC mill with a home-brewed speed increaser/engraving spindle/sprung Z-axis slide which allows me to do all the things the IM3 can do plus full 3D engraving paths for sharp corners on deep cut engraved fonts.
    If you have any questions feel free to ask,
    Regards,
    Nick
  7. The Following User Says Thank You to magicniner For This Useful Post:
  8. #6
    Quote Originally Posted by lucan07 View Post
    Yes that the type of thing they use they have circular disks of fonts .
    That's ring engravers, not the IM3.
  9. #7
    and even work inside rings with one of them of them..
    Scratch engraving ring engravers, not the IM3
  10. #8
    Yes I know they have been in the business over 30 years and have all sorts they can do rings or plate withsame machine templates a pantograph type arm that also runs from exact same disks and you dial in and move along like an old pressure tape label makers only with drag or power engraver running on the arm or the micro tools on inside or outside of the rings which obviously rotate instead of moving.
  11. #9
    Lives in East Lothian, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,970. Received thanks 369 times, giving thanks to others 9 times.
    Frank,
    have a look over on the CamBam forums, in the Members Projects board (http://www.cambam.co.uk/forum/index.php?board=9.0), for the watch threads (there's two that I know of) by Arie kabaalstra. I know his current machine is reasonably expensive, but that was an upgrade after he started producing watches commercially.
    His posts give a good insight into fine work, which I'd think would give you a good insight into the process (design, work holding, tooling etc)
    There was also a ring maker over on the mach support forums, however I can't remember his username, and it's been a few years since I noticed him post.
    Regarding machines, it'll depend on if you want something turnkey, or to convert something your self. If you want turnkey, of the top of my head I'd suggest looking at a Seig KX1 (Arc Euro Trade sell them), or there's a Swiss company who do a good range of smaller milling machines including CNC options, but I've forgotten their name!
  12. The Following User Says Thank You to m_c For This Useful Post:
  13. #10
    Regards,
    Nick
    Hi Nick
    I can get the IM3 with Motor, 2 fonts and some blanks for a tad less than the above. I don't know about the depth guide but will ask.
    I have seen the machine do scratch engraving on cufflinks, but would like to know the type of items and material for the deep rotary cut/milled engraving.
    At the moment, everything is new to me, Metals, plating the machines etc. I assume that the deep engraving cannot be done on Plated metals ?
    Which CNC machine do you now have ?
    Many thanks for your help - its appreciated.
    Frank
  1. Entry level Probe
    By Leadhead in forum Probing, Digitizing & Scaning
    Last Post: 09-10-2013, 07:55 AM
  2. help needed going to the next level
    By luke11cnc in forum Computer Software
    Last Post: 20-09-2012, 08:53 AM
  3. Which end mill to level my acrylic bed?
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 03-02-2012, 02:57 PM
  4. Which Bench top CNC machine for jewellery etc
    By Claymore in forum Machine Discussion
    Last Post: 16-11-2011, 08:39 PM
  5. Level Y Axis
    By sfallan in forum Machine Discussion
    Last Post: 26-09-2010, 12:52 PM
