Page 11 of 50 FirstFirst ... 91011121321 ... LastLast
  1. #101
    Chaz's Avatar
    The ribs won't add any strength without rebar. the mix for small cross sectional beams/lintles ect is 3parts aggregate(10mm) 2 parts sharp sand 1 poart cement. but you still need the rebar.
    i feel really bad about this as i should have mentioned it earlier.
    But you seem to have gone into it in detail as you have with the rest of the build.
    Mike
    No problem. Lets see how it holds out.
  2. #102
    Chaz's Avatar
    Quote Originally Posted by Fenza View Post
    http://www.moertelshop.com/PCE-Flies...uenstig-kaufen
    Polycarboxylate is the normal liquid superplasticizer. The shop I just linked seem to be pretty good and reasonably priced.
    I'm going to try them out for some of my own experimentation.
    Cheers,
    Fenza
    Looks similar to what I am using but mine is a bit lighter. Same idea however.
  3. #103
    Chaz is the colour from the super plasticer or have you added pigments.? Also expected that you would have added fibres.?
  4. #104
    Chaz's Avatar
    Jazz, the cement is white. Snowcrete (basically). The stone is black and the sand then, well brown. The plastisizer is a light colour .... I suspect most of the colour is the mix of sand and cement.
    I did not add fibres. It was discussed (with the guy providing me bits) and in his past experience it was pain to do and he did not feel worth it.
  5. #105
    Erm not sure I've mixed plenty of plain concrete and it doesn't go that colour. Think something is having an affect.? maybe because less water.?
    Erm that surprises me because most of the polymer concrete bases I've seen have used fibres of some kind to bind together.?
  6. #106
    Chaz's Avatar
    What cement did you use? Normal grey stuff?
  7. #107
    Ye just normal portland cement and to be honest looking again I think this cheap monitor I'm using is probably some of the reason it looks funny.!!!
  8. #108
    Chaz's Avatar
    Lol. Ye, the 52.5R stuff is whiter than the white we are typing on here ....
  9. #109
    Chaz's Avatar
    Stolen from someone's website. These are walls made from the same stuff. Colour is similar.
  10. #110
    Probably why it's called SNOW Crete then. . Lol
  11. The Following User Says Thank You to JAZZCNC For This Useful Post:
There are currently 15 users browsing this thread. (0 members and 15 guests)
