17-09-2009 #2
The Gibb strip can bend, it's the other side that may be the problem.
Suggest you loosen the Gibb, seize the saddle with both hands, shove it hard up against the Vee on the non-Gibb side of the bed and then twist it.
Does it rock or does it roll? You should be able to feel if the contact face has bowed.
taper roller bearings vs deep groove ball bearings
By dsc in forum Linear & Rotary MotionReplies: 8Last Post: 10-03-2014, 08:06 AM -
RFQ: Parts need turning
By ams in forum Projects, Jobs & RequestsReplies: 17Last Post: 15-01-2014, 12:27 AM -
Morse taper drills
By John S in forum Marketplace DiscussionReplies: 7Last Post: 08-05-2013, 07:00 PM -
larger home made milling spindles - NMTB/ R8 taper?
By jonnydeen in forum Tool & Tooling TechnologyReplies: 6Last Post: 13-09-2012, 11:17 AM -
FOR SALE: Clarkson Autolock Collet chuck set, Boxed INT 30 / NMTB30 taper
By swarf-boy in forum Items For SaleReplies: 0Last Post: 04-01-2011, 05:28 PM
