11-11-2016 #5
Hi Lee,
The biggest differences are in the number of inputs/outputs. The UC400ETH has 2 standard parallel ports (LPT type) while the UC300ETH has 2 LPT type and 3 DB25 with mostly inputs and additionally even 2 analog inputs and 2 outputs, so it is pretty well equipped and has more in/outputs than I'll ever need. The UC400ETH does not have any analog I/O at all, which isn't really important for me at the moment since I control my spindle via Modbus and RS485ETH.
Most probably I will move everything to UCCNC mecause it is in many ways better. Unfortunately, the move is not that simple because I have to rewrite my macros since Mach uses VB and UCCNC uses C#. Also, UCCNC does not have radius compensation (yet) and that is something I frequently used, so I have to regenerate everything without if I move to UCCNC.
The Mach3 plugin means that I am not in a hurry now, but with the UCCNC and the UC300ETH I get higher speeds and better results than with Mach, so there is indeed an advantage in leaving Mach3. UCCNC has also some functions which does not exist in Mach3, and in general I like it more than I like Mach.Last edited by A_Camera; 11-11-2016 at 02:48 PM.
The Following User Says Thank You to A_Camera For This Useful Post:
CNCdrive.com Cheap Servo drives
By BillTodd in forum Marketplace DiscussionReplies: 2Last Post: 13-06-2017, 11:38 AM -
Anyone using CNCdrive products?
By gatesy in forum Machine DiscussionReplies: 20Last Post: 27-12-2015, 11:13 AM -
Huanyang VFD control plugin for Mach3, USB RS-485
By JayPunchbuggy in forum Spindles & Drive MotorsReplies: 19Last Post: 15-05-2013, 08:00 PM
