    That breakout board is just a bunch of screw terminals, not optically isolated. I'd not use that with any of the CNC Drive products. There is even a warning about this in their manuals.
    I've got something similar but I've also got one of these: http://m.ebay.co.uk/itm/252307419456
    ...as well. There is so many options these days, i think moving away from LTP and/or USB is a good move though.
    Yes, definitely agree that LPT and USB are not exactly optimal year 2016.
    BTW, I have two identical BOBs. They also have 0-10V and are very goodand in my opinion. That BOB has six optically isolated inputs which are driven separately from the 5V logic if connected properly, outputs are through buffer driver and the relay is useful.
    Well had a look at the 300ETH manual and it's not exactly helpful is it ?
    22 Pages, 20 of which tell you how to connect the ethernet and then a scant 2 pages giving the wiring of the pins.
    aHowever they are all marked output 1, output2, etc, Analog 1, analog 2
    Would it really hurt these peole is they supplied a diagram for a working 3 or 4 axis machine with VFD ?
    You know it just might, note I said might, improve sales because at the moment anyone who isn't an EE is totally fazed by what has been released.
    BTW can it do multiline encoder for lathe ?
    John S -
    The UC300ETH basically has 5 parallel ports. There are different motherboards available which dictate the input and output pins.
    Two ports are standard, and 3 ports use pins 2-9 as inputs.
    The CNC4PC M44 board has 3 parallel ports, and two special ports, one for inputs, one for outputs. One of the 3 is standard and two use pins 2-9 as inputs.
    You plug in your breakout boards and wire it any way you want, just like a standard parallel port.
    The analog I/O uses a separate header.
    There is no lathe screen at this time. It does rigid tapping, so it may be able to use a multiline encoder. Not positive, though. Send them an email, they are very good with customer service.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  5. The Following User Says Thank You to Ger21 For This Useful Post:
  6. #5
    What's your hardware setup Gerry ?
    I'm confused, so do you need to buy a motherboard or dose it come with the one in the pic and shown in the manual?
    I think that it depends where you buy it from.
    CNC4PC sells the motherboards separately. I think if you buy it from CNC Drive it comes with their 5 port motherboard.
    Currently, it's sitting on my desk with a $5 chinese breakout board, plugged into the M44 motherboard. I'm just using it for testing and screen design work right now.
    Not sure what breakout boards I'll use on my router, as it's still a year away. Maybe the C62, and an M23 for additional 24V inputs.
    Or two C10's and an M23, which is a lot cheaper.
    It's really flexible, and lets you do pretty much whatever you want.
    I'll be running a mix of four DMM 400w AC servos and two steppers.
    Gerry
  8. #7
    What help do you need or what is missing according to you?
    Well, the 13 page about the network setup is a bit too much, probably could be cut down to 1 or 2, but if it was, I bet you somebody would complain about being too condense. Actually, 5 pages are about wiring and that's all needed, at least for most people. I agree though that they should have combined the UC300USB and UC300ETH manuals, because especially with Mach3, some features are not explained in the UC300ETH manual.
    No, they are called Port #1, Port #2, Port #3, Port #4, Port #5 and Analog. Pins which are called "Input" are input pins, and those called "Outputs" are obviously output pins. Analog input 1 and 2 marks the pins which have the function of being analog input 1 and 2, likewise for analog outputs 1 and 2. If an input or output pin has the same name, it has obviously the same function because they are opposite each other and they are electrically connected to each other, for example there are two pins marked Analog input/output 1 and 2 and those are obviously the same (i.e. analog input 1 on pin 3 is the same as analog input 1 on pin 11) and not typo.
    I think all that is very clear to anyone with a not so negative attitude.
    Would it really hurt being more positive...?
    Perhaps they assume that a person buying such card knows why he/she is buying one and can connect it. Regardless of which, it is mentioned in the manual that it should be connected to a breakout board, and all those I have seen had a diagram about how to connect a machine to their BOB.
    You know it just might, note I said might, not really matter. Why? because people who are seriously interested have a different attitude and are willing to risk this small sum of money just to try it out. Also, people in general know that CNC Drive is providing excellent support, so I am pretty sure that a person who has problems with connecting the motion controller would get all the help needed. But... there will always be people who are never going to be satisfied... If they would have a manual containing hundreds of pages, describing basically everything, the price of the product would be higher and then some other people would complain that they are too expensive. Remember that CNC Drive is not a hobby for them, it is a company paying their daily bread. Also, perhaps very high volume is not their target, some time it is better to find the customers who KNOW what they need and want than finding too many customers who don't have a clue.
    No, you don't need to be an EE to be able to use their products, but sure, you need to have some basic electrical understanding about what you are doing and why. You not really qualify as an EE if you manage to connect their UC300ETH.
  9. #8
    Wiring diagram or more information.
    We must be looking at different manuals then. Last page in mine where it finally lets go of the ethernet wrestling match is page 18 of 22
    Pages 19, 20 and 21 cover pins in terms of inputs and output numbers, page 22 is a picture
    Not being told anything and my reply is negative. ? Then to be told on a forum I need one of Arturo Duncan's cards to make it work ?
    Just looked at the CNC4PC site and the M44 board which now tells me I need a C23 / C25 / C32 M21 / M23 / M25 / M27 / or M41 board as well.
    Glad that cleared that up.
    Did you ever see the picture of the shelves above my desk where I have probably built over 100 CNC machines ?
    It's full of boards that don't work, promise the earth and never deliver or take your money and never reappear again.
    Sorry negative or not, I don't have the time to piss about and why should I . ? If the manufactures can't supply a finished working product then stuff them, there are plenty who can.
    I'm SERIOUSLY PISSED OFF wasting months and years of my life whilst idle people get others to do their work for them.
    Why should I buy 2, 3 or even 4 pieces of equipment off different suppliers who won't even talk to one another and I'm expected to be UNPAID piggy in the middle.
    John S -
  10. #9
    Ye and you ain't got many years left ya Old Git so Chill out else you'll blow fuse early. .
  11. #10
    Yes Jazz but it has an inverse reaction, the more bad press they get the more they have to pull their socks up and the better it makes it for everyone else.
    It's just a pity it has to be this way.
    John S -
  1. CNCdrive.com Cheap Servo drives
    By BillTodd in forum Marketplace Discussion
    Last Post: 13-06-2017, 11:38 AM
  2. Anyone using CNCdrive products?
    By gatesy in forum Machine Discussion
    Last Post: 27-12-2015, 11:13 AM
  3. Huanyang VFD control plugin for Mach3, USB RS-485
    By JayPunchbuggy in forum Spindles & Drive Motors
    Last Post: 15-05-2013, 08:00 PM
