Thread: Help with haas vf0e
17-11-2016 #15
.......Approach the problem logically, if there are no blown components or tracks on the board and you have proven the PSU is not delivering the correct voltages then replacing the PSU is an entirely logical next step.
An ATX PSU doesn't just deliver all the correct voltages all the time though, it has some permanent outputs but requires a logic signal back from the board to which it connects to tell it to power up fully. If the new PSU doesn't "Fire up the Quattro" then you should check to see if the board is providing the required signal telling it to turn on,
Regards,
NickYou think that's too expensive? You're not a Model Engineer are you? :D
Haas Hl2 lathe assitance S70 area
By MAW in forum Lathes, Lathe Rebuilding & ConversionsReplies: 2Last Post: 05-09-2016, 08:09 AM -
Haas mini mill spindle ramp up time
By Hellfire in forum Machine DiscussionReplies: 2Last Post: 16-05-2016, 10:33 AM -
Haas vf-0e 1995
By jackpat in forum Machine DiscussionReplies: 0Last Post: 13-05-2016, 11:18 AM
