    Quote Originally Posted by Agathon View Post
    Just a final thought on the closed loop steppers. Given the details of the original motors, do you think the Leadshine 3ph Nema23 2Nm motors would provide enough torque?
    Difficult to answer without seeing machine etc but the fact the old where 34's and probably wired in series which gives more torque lower down Rpm then it will be close call and one I wouldn't take personaly.
    AM882 and 34's would be safer bet.
    Lives in East Lothian, United Kingdom. Last Activity: 8 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    It's a shame that the Leadshine Am882 doesn't appear to be available in the UK. Is there another driver worth considering?
    The AM series has been replaced by the EM series. The new AM882 equivalent is an EM806.
    The original HS closed loop stepper system has also been replaced with the Easy Servo range.
    Ouch, those EM806 drivers are pricey - by the time I've bought a motor, I've exceeded the price of the Nema34 closed-loop units from Rattm motor in Germany (http://r.ebay.com/jCcjOw).
    I notice these drivers claim to be digital - http://r.ebay.com/chJSF8
    Don't be fooled by the Germany part. They will come from China. You'll get message saying don't have stock in Germany and will be 6-8wks before re-stock and would you like them sent from china.
    Don't be put off buying from china if you can afford to wait. You'll get AM882 cheap enough. I've used lots both EM and AM there's very little between them in performance terms.
  5. #15
    Very good advice as usual. Many thanks.
  6. #16
    Just to throw something else into the mix... I contacted Fehlmann (the makers of my mill) and asked them what they used on the modern equivalent of my machine. They now use Omron "Smartstep" servo motors (R88M-G40030h) with a nominal torque of 1.3Nm and a momentary torque of 3.6Nm. 2.6A mains (200v ac) powered driver.
    I'm wondering again whether those Leadshine 3ph Nema23 2Nm closed loop steppers wouldn't do the job or is the torque characteristic for a servo very much different to a stepper?
  7. #17
    Very different.!!
    The 1.3Nm is continous meaning thats what you'll get at full motor speed probably 3000rpm. The 3.6Nm is Peak torque which the drive/Motor can handle for limited period of seconds which is often enough to handle high enertia or heavy starting loads. Under heavy loads ie: cutting it will handle anywhere between 1.3nm & 3.6nm for limited periods depending on loads.
    Throw into the Mix that because Rpm is often much more than required there will ratio applied so torque actually increases.
    Stepper rating on the other hand measured at ZERO RPM and starts to drop as the Rpm's increase. Slowly at first up until point of the Speed curve where it starts to drop quickly untill full motors coils reach full saturation and motor stalls. On 34 motor the speed curve will be aprox 900rpm depending on inductance and voltage used. There'll be little to no torque at 1500rpm.
    This is why inductance and Voltage is so important to the speed you get from steppers. Also you throw how stepper is wired into the mix and it can change again.?
    If wired parallel you'll get torque higher up the rpm range but less lower down for set voltage. If wired series you'll get pretty much the opposite, Higher torque lower down rpm range but motor will reach saturation much sooner for the same voltage so lower RPM.
    Most 34 motors are 4 wire series wound motors and to get any decent speed from them requires High Voltage. Often larger Nm 34's are run with mains voltage drives.
    Now for mill you won't require high rpm's so series wound is often Ok. Nema 23 motors often come with 8 wires and can be wired series or parallel. But the same applies in that higher voltage is required for same rpm if series wound.
    So in nut shell if they Fit 1.3nm Servos then 2Nm Nema 23 Stepper isn't going to cut it really.
  9. #18
    Very clear reply - thanks.
    OK, so just to confuse myself more I've tried to fill out the Excel motor calculator here - http://www.mycncuk.com/threads/1524-...otor-do-I-need
    I've attached the calculation with what I think are generous values using the Leadshine 3ph 2Nm motors LS2NmMotorCalcs.xls
    This seems to look OK, but have I missed something - are my estimates as to load mass and table speed too low? The 3ph 2Nm Leadshine motors have an encouragingly flat torque curve at less than 360rpm - Click image for larger version.
    If I go for conventional steppers I'll go with the AM822 drivers, but what size motor? The old steppers have a surprisingly small shaft (3/8") so Nema34s with 14mm shaft are a bit of nuisance. I see Nema23 3Nm motors with 10mm shafts - http://r.ebay.com/KuT9Ez - Are these big enough though?
    Sorry for all the questions.
    Just to give some idea of the sort of machine - here's a (bad) photo:Click image for larger version.
    As you can see, it's a kind of mill-drill. But don't be fooled, this thing is a beast weighing in at about a tonne. The table weighs around 150kg - hence my 100kg load per axis estimate. The motors drive the ball-screws directly.
  10. #19
    My gut instinct for a machine like that with direct drive steppers, would be something in the 4Nm range to give plenty safety margin.
    I think personally I'd consider altering things to use a belt drive with some Nema23 steppers, which should give you better performance. With big Nema34 motors, for best performance you've really got to use high voltage drivers, but you're then still limited at torque drops of quite quickly with big steppers.
  11. #20
    Thanks. I had considered driving via a belt just in order to make the machine more compact. Would you gear up in order to increase the speed of the ball-screw relative to the stepper?
  1. Electric motorbike racing
    By Jonathan in forum General Discussion
    Last Post: 16-08-2016, 03:28 PM
  2. Need assistance with electric enclosure please (CSMIO/AC Contactor issue)
    By Noplace in forum Electronic Project Building
    Last Post: 22-01-2016, 12:09 PM
  3. FOR SALE: 240v decent electric filter
    By DrNik in forum Items For Sale
    Last Post: 16-03-2015, 12:30 PM
  4. Recommend a superior stepper motor driver IC to you.
    By lihaijiang in forum Motor Drivers & Controllers
    Last Post: 16-12-2011, 09:11 AM
  5. FOR SALE: Metabo 710W 230V Electric spindle, stepper motors, Tr nuts 20x4
    By Vladimir_MD in forum Items For Sale
    Last Post: 09-04-2010, 05:24 PM
