End plates for a gantry? So what happens when you accelerate the head hard along the gantry or the tool plunges in to the side of something resilient? That is the moment you realise that a plate simply does not cut the mustard and you really needed to think in triangles.
Well, the Nema 23 will probably stall if all of the end stops fail. Chances of that happening......
What happens if I'm using a tube design with thin walls and the plate rams the thin skinned tube?
Here is the basic design.
The Y extrusion is quite big, 80x160, and the others are all 80/80 profile.
This is the rough plan
This is where I'm up to
ID:	19821Click image for larger version.
To be used for 3d Printing, Composite 3d milling, wood, and possibly aluminum
