Thank you Jazz,
I think with your explanation (much clearer than a lot of info I have found online) and the one from Neale has clarified things immensely to be honest.
I was having a little play with the BoB today and with a meter I could see the voltages coming out of some of the pins (not quite 5V but 3.6V, which may either be normal or it's because I have had to use a PCI expansion slot in the PC as it didn't come with a parallel port). My next step is to get a dedicated PC assigned for the job, install Win7(32 bit) and then install Mach3. Then I think I will be on the home run!
Thanks again for saving me a lot of hair-pulling.
Rob
07-12-2016 #2
Possibly because of the PCI. It's very common for modern PC's to only supply 3.6V. However this is BAD NEWS for CNC and you need close to 5v to work correctly.
With 3.6V you will have trouble because there isn't difference between HIGH and LOW.?
When I said 0v and 5V I actually should have also said LOW & HIGH because that what really matters to CNC. LOW is anything from 0v to 2.5v HIGH is anything thing from 3.1 to 5V.
So with only 3.6v there not enough difference between Hi - Low signals and just slight difference or drop in voltage can cause missed steps and all sorts of strange happenings.
Only letters could put after my name are "NFC" or "CFS" but Hope that helps expalin little more.Last edited by JAZZCNC; 07-12-2016 at 08:27 PM.
07-12-2016 #3What's wrong with DCM (don't come Monday)Only letters could put after my name are "NFC" or "CFS" but Hope that helps expalin little more.
That's why as you know you need a bob with a level shifter to bring them back to 5V or a decent motion controller.So with only 3.6v there not enough difference between Hi - Low signals and just slight difference or drop in voltage can cause missed steps and all sorts of strange happenings.
07-12-2016 #4
That BoB is a Larff innit ! £16 for a D25 to screw terminals connector.
A chinese 5 axis BoB will do isolation, spindle control, coolant relay all for a small Bank of England drinking voucher. I wouldn't put that connector board anywhere near my computer (apart from the bin next to it).
Rob (if you want the letters behind my name it's 'F. in B.;VD and scar')Last edited by cropwell; 07-12-2016 at 11:41 PM.
BUILD LOG: Ar last!!! Started my Gantry 3-Axis CNC Build
By MikeyC38 in forum DIY Router Build LogsReplies: 74Last Post: 16-06-2018, 11:29 PM -
Fixed Gantry small precision begineer project advice
By yasu in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 17-10-2016, 07:14 PM -
Fixed z axis to gantry design
By Lachlan in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 20-10-2015, 09:50 PM -
Driving the gantry on Z axis?
By Skipsoaring in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 11-06-2015, 09:26 PM -
Gantry design advice please
By D-man in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-11-2012, 04:17 PM
