27-12-2016 #2
27-12-2016 #3
I just like the way you assumed I needed to be more careful. What exactly gives you the impression I haven't been?
Hence the reason I will see how it goes when it's done. I've endeavoured to make it as square as possible on all axes and feel comfortable that I've managed to achieve that within the best of my ability.
I'll be sure to let you know if you're right or wrong once it's done and I tweak everything :)
Sent from my SM-G920I using Tapatalk
BUILD LOG: Desktop size steel welded router 3 axis
By Tom J in forum DIY Router Build LogsReplies: 84Last Post: 28-03-2017, 09:36 PM -
Z-axis huge slack / beginning a conversion
By diy-john in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 04-03-2012, 10:26 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM -
CONVERSION: Buget Warco Major 5 axis conversion
By Tweaky in forum Conversion Build LogsReplies: 45Last Post: 07-10-2010, 04:26 PM -
Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
By No1_sonuk in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 17-05-2010, 12:47 PM
