    I've used ASC - good service etc.
    In my case, would you use Mild Steel or Alu for my Z setup?
    Yes ;)
    Aluminium is much easier to machine...
    Chaz's Avatar
    Yes ;)
    Yep, doesnt make it better though :-|
    I could probably weld the plates up to leave the slot for the bearing / ballscrew. My Denford can do mild steel machining without too much of a problem - albeit fairly slow going.
  1. Milling mild steel
    Last Post: 16-02-2014, 02:31 PM
  2. RFQ: Several mild steel parts
    By dudz in forum Projects, Jobs & Requests
    Last Post: 26-08-2013, 11:37 AM
  3. Replies: 25
    Last Post: 03-05-2013, 09:31 AM
  4. Cutting 1.6mm mild steel with a CNC machine?
    Last Post: 01-05-2012, 09:56 PM
  5. Homemade desktop CNC - cutting 0.8mm mild steel out the question?
    Last Post: 16-04-2010, 09:37 AM
