Thread: Where to get Mild Steel Plate?
I'd go with steel if could work with it. However I'd only use it if could do it correctly which means will need heat treating and stress reliefing then grinding in critical places.
If you can't do this then you may find Ground tooling plate will be more accurate as it's already been heat treated and ground flat.
Plug welding will allow thinner plate to be used but all the above still applies and will require more work because all that heat will warp and put stresses into the whole assembly. If those are not released carefully then they will release eventually which will make for bad day when you do realise.!!Last edited by JAZZCNC; 31-12-2016 at 10:00 AM.
31-12-2016 #2
31-12-2016 #3
31-12-2016 #4
Chaz,
I am about to place an order with Misumi. If you do the leg work and find the part number for the piece you need I will order it for you.
http://www.misumi-europe.com/en/cata...0/M1401020000/
Regardshttps://emvioeng.com
31-12-2016 #5
31-12-2016 #6
in 3-5 days from now
31-12-2016 #7
31-12-2016 #8
01-01-2017 #9
Happy new year! Yes i can see prices. A quick quote gave me around £50 for a ground plate iirc. Send me a pm with the part numbers and i will get you their prices from the site.
The Following User Says Thank You to komatias For This Useful Post:
Milling mild steel
By dudz in forum Machine DiscussionReplies: 33Last Post: 16-02-2014, 02:31 PM -
RFQ: Several mild steel parts
By dudz in forum Projects, Jobs & RequestsReplies: 6Last Post: 26-08-2013, 11:37 AM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM
