Quote Originally Posted by dachopper View Post
So it was a busy Christmass
Went with 20mm thick
What do you think?
Hi Nick
You have been busy! so have I, finally got my machine cutting. Anyway the 20mm plate on the gantry sides will give stiffness in the Y/Z plane. BTW I noticed on your Z-axis plate the bolts are raised. You should counter bore these so that the trucks for your Z axis will have some where to be located. Remember Jazz's comments about mounting the rails on the back of the plate which holds the spindle and the trucks and ballscrew get fitted to the plate as shown in your photo.
All the best and have a successfull 2017!
Regards
Mike
