    In practice, then, just what size capacitor will do an adequate job without going OTT? What is the effect of a too-small capacitor? Don't know the answer myself, but once my machine is back running I'll stick an oscilloscope on the PSU output and see what's happening, just in the interests of science.
    1000uF for 1A, voltage is important (20% more than operating voltage and you are safe, min 100V caps for 80V system.)
    Small capacitor won't take enough power from stepper when slow down or change direction (EMF). I am scared to write anything now
    Lives in East Lothian, United Kingdom. Last Activity: 3 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Quote Originally Posted by Tom J View Post
    The thing is, that 1000uF per A is an arbitrary figure provided as a guideline.
    I just had a quick scan through the Gecko Drive guide, and they list the following formula for minimum capacitance in uF-
    (80'000 * I)/V
    I'd imagine they've done some calculations and research to reach that figure, and it'll involve the maximum voltage ripple their drive internal capacitors can handle safely under various conditions.
    Anyone wanting to make one Jonathan is selling these http://www.mycncuk.com/threads/10475...al-transformer. A bargain I think.
    A few months ago I said that I would have a look at the output of my power supply with an oscilloscope to get a feel for what was happening to the supply voltage with the router in operation. I was able to do this recently. I had some gcode running that was winding X and Y backwards and forwards at full rapid speed (gantry probably weighs in at around 50Kg, rapid speed on X and Y 4.5m/min, NEMA23/ballscrews, to give an idea of mechanical load), and I hung the oscilloscope off the supply to one of the drivers. Basically, there was the best part of 10V mains frequency ripple, with maybe a couple of volts of high-frequency noise on top of that. Mains ripple was presumably what the smoothing capacitors could not remove, and the high-frequency noise was the combined result of four unsynchronised switching drivers. That's all on top of a nominal 68V DC supply - the output voltage was swinging either side of that. The amount of ripple didn't change very much when the steppers were stationary although the stepper drivers are set to half-current mode. Clearly that doesn't make much difference to the PSU ripple.
    Edit - have now seen that PSU has 2x6800uF smoothing capacitors, 100V/105C rated. Voltage limit is fine for this job and it's good to see the higher temp capacitors being used rather than the cheaper 85C - electrolytic capacitors are not the most reliable of electronic components but the higher-temp versions are better.
    On the face of it, that doesn't sound like a great result. I was surprised by the amount of ripple - much more than expected. I can't read the capacitor values where they are, unfortunately, so I'm not sure how generous they are (the original PSU is the PS806 from Zapp although with a replacement transformer). On the plus side, the stepper drivers clearly don't give a damn and just keep on doing what they are supposed to be doing, and do it very well. Maybe, just maybe, it's possible to get a bit too hung up on the details sometimes and worry unnecessarily.
  5. The Following User Says Thank You to Neale For This Useful Post:
  1. 2 x Toroidal transformers question
    By Proteus in forum General Electronics
    Last Post: 20-10-2016, 10:28 PM
  2. What Toroidal parts do i need
    By amxen in forum General Electronics
    Last Post: 27-09-2014, 10:53 PM
  3. Toroidal Transformer
    By Carlb1058 in forum General Electronics
    Last Post: 17-08-2013, 06:54 AM
  4. sourcing transformers
    By adscnc in forum General Electronics
    Last Post: 20-11-2010, 11:05 AM
