Thread: 10mm belt nema23
28-01-2017 #4
What is the output power of your 36V PSU? How many motors and how long are they? Do you know their voltage and inductance?
I doubt that the steppers are the problem.
You have a 20 tooth pulley with 10 mm pitch? This means you are moving 200 mm with one motor rotation. At 800 mm/sec your motor has 240 RPM which isn't that high.
At high speeds acceleration is important. Unless you are cutting very large parts, you will hardly get to your max speed. Better the acceleration, quicker you'll finish the job with the same feedrate.
10mm belt and nema 23
By kev20009 in forum Belt Drive, Pulleys & TimingReplies: 0Last Post: 27-01-2017, 11:52 AM -
eBay Nema23 Stepper mounts
By Slixxor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 05-06-2016, 05:02 PM -
Anyone have a UK source for open ended 10mm T5 Polyurethane belt
By cweeks in forum Linear & Rotary MotionReplies: 18Last Post: 19-03-2016, 09:43 AM -
RFQ: RFQ Nema23 stepper mount
By r0bsk1 in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-02-2014, 02:16 PM -
DIY Nema23 Motor Mounts
By Lee Roberts in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 23-08-2009, 06:08 PM
