18-02-2017 #10
I'm guessing something like this http://www.zappautomation.co.uk/elec...er-supply.html
Yeah these things can snowball, one more expensive item leads to another and so on... reality is most of us are working to a budget so you need to figure out what you are willing to spend and what will be sufficient for your needs.
If budget is starting to pinch, I would also take a look at what areas it's best to put your money into initially. Might be an idea to go for the better controller (e.g. the CSMIO IP/M mentioned above) and just make do with the cheaper steppers until you feel the need to upgrade.
Ultimately of course you end up spending more by buying cheap then replacing, but reality is it gets you up and running in the mean time.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
