    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Saracen View Post
    Excellent find see #2 Kev
    That BOB looks like the zp5a-int. Quick Google search will turn up a manual for it and you might be able to find some sample connection diagrams. Each axis has three signal outputs (pulse, dir, enable) and ground. I can't remember if it can sink current or just source it but those driver connections sound as if they need the BOB to sink current (open collector output). I think I used mine to source current into driver opto-isolator inputs. I was using this with M752 (big brother of driver mentioned in link given above) but driver described by OP sounds as if its input connections are rather different.
  4. by the sounds of it the driver has a common anode where the VCC (5V) is powering the opto and it is stepping when the pulse and pulled to gnd. (NPN)
    the breakout board outputs a 5V to step. (PNP)
    I think that gives you the answer to your question.
    Quote Originally Posted by Gary View Post
    ...which is that the BOB is not going to work with that driver. Not by the sound of it. Any more info on the driver?
  1. voltage on motor wires
    By phill05 in forum General Electronics
    Last Post: 11-02-2012, 03:43 PM
