Page 1 of 6 123 ... LastLast
    I saw the lack of decent draw slide builds on you tube prompted me to make one better than whats currently on offer on you tube so here it is... unfinished of course !!!
    cutting area should be 260mm x 350mm once finished
    Attachment 20659Attachment 20660Attachment 20652Attachment 20654Attachment 20655Attachment 20661Attachment 20662Attachment 20663Attachment 20658Attachment 20657
ID:	20777   Click image for larger version.
ID:	20778   Click image for larger version.
ID:	20779   Click image for larger version.
ID:	20776   Click image for larger version.
ID:	20775   Click image for larger version.
ID:	20774   Click image for larger version.
ID:	20773   Click image for larger version.
ID:	20772   Click image for larger version.
ID:	20771   Click image for larger version.
ID:	20769   Click image for larger version.
ID:	20768   Click image for larger version.
ID:	20767   Click image for larger version.
    ROTATING IMAGES
    @steel: "Again pics are rotating somehow when i upload them anyone got a fix for that ?"
    My way may not be the easiest way, but to fix this from the laptop I use an excellent and free product called IRFANVIEW http://www.irfanview.com/ and use function Image>Rotate Right (Clockwise) and then save the modified image, as I've found that the Windows Explorer function Rotate Clockwise/Counter-Clockwise is not honoured across different software apps.
    Thanks Andy managed to rotate them in preview on the mac strange though as i rotated them 360 deg and there the right way up this time. !!
    Well thats day of your life you'll never get back.!!!
Name:	z axis1.jpg
ID:	20792Click image for larger version.
Name:	z axis2.jpg
ID:	20793Click image for larger version.
Name:	z axis3.jpg
    Just a few photos of the z axis, shafts are 12 from some old rear shocks from a car, bushes are nylon diy held down with u bolts
    Just a few more photos of the z axis, i will fit the lead screw tomorrow if all goes well.
ID:	20833Click image for larger version.
ID:	20834Click image for larger version.
    finished off the z axis today, i finally gave up on having supported bearings on the lead screw and mounted it directly to the motor as ill only be using this machine for wood/plastics it wont be a problem
    https://youtu.be/cj665WQhmYU
    So today I made some progress...
    I mounted x axis to the base
    I updated z axis face plate to alloy insted of ply
    I decided I didn't want the y axis motor sticking out the side so
    I mounted it inboard
    Im using my cheap ebay router
    overall Dimensions are as follows...
    Length of base 550mm
    Width of base 500mm
    Height overall 800mm
    cutting area...
    X 400mm
    Y 260mm
    Z 90mm
ID:	20902Click image for larger version.
ID:	20903Click image for larger version.
ID:	20904Click image for larger version.
ID:	20894Click image for larger version.
ID:	20895Click image for larger version.
ID:	20896Click image for larger version.
ID:	20897Click image for larger version.
ID:	20898Click image for larger version.
ID:	20899Click image for larger version.
ID:	20900Click image for larger version.
    Sorry to sound negative, but you will kill that Z stepper very fast if you start using the machine. The screw seems to be hanging on the motor axis, which is a VERY bad idea, since the motor and the motor bearings are not designed for that heavy job. Same on all the other axes as well, but the Z is probably the most critical, and at least one end of the screw must be fixed. I also don't understand why use drawer slides. Those have just too much play and are not fit for the purpose. But OK, if learning is the purpose then fine, but considering the time you must spend on this, I am sure that real parts are better investment than parts which later on must be replaced, especially considering that replacing and squaring will be very difficult since you have welded everything possible to weld.
    Don't be sorry the world is full of negative people !!! the stepper bearings will cope no problem,I am using heavy duty draw slides as i wanted to build a machine that uses alternative components as much as i can
    Can you do me a favor and start a thread on your machine that way you can remove your links from my post and place them on your own post
    cheers Dave
  2. BUILD LOG: Desktop type router - Fixed gantry - steel frame MK2
    By Tom J in forum DIY Router Build Logs
    Last Post: 02-01-2017, 09:32 PM
  3. Small Fixed Gantry Router Spec and Build
    By shaunrod in forum Gantry/Router Machines & Building
    Last Post: 29-07-2016, 06:55 PM
  4. BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
  5. BUILD LOG: New build - fixed gantry mill using extruded profile
