    Something to consider might be a double plate set up when attaching the y-axis. This allows for easier adjustment.
    In essence the y gantry sides have a base plate attached to form a y-axis assembly. This can then be bolted to a matching plate that is attached to the x-axis carriages.
    See http://www.mycncuk.com/threads/10403...aver/page4/#31 & the following post for a better explanation.
    This can be seen in a very recent post of the finished machine here (post #69)
    http://www.mycncuk.com/threads/10403...aver/page7/#69
    Good point of the double plate for easier adjustment.
    If you want a stronger machine...
    Regarding the length of the X axes screws and the overall length of the machine I do not see why you need the frame longer than the linear rails. If you lower the ballnut mount with a spacer and move it to the back (closer to the motor) you can shorten the screw at front by at least 10 cm, having the end blocks going under the gantry base plate.
    Oooohh, nice one. Definitely need to give that a go. Thanks for that.
    In fact, thanks to everyone. Sop far all the advice has been spot-on and seriously helpful.
    Being such a noob, it just occurred to me while working on the detail that I have no idea if I should go for tapped holes or use nuts (nylocs?) instead. Is there a rule of thumb for this sort of thing?
    Quote Originally Posted by Greeny View Post
    It's definitely something to consider as a future mod, or son-of- machine. I really like the concept. Right now, since this is my first ever build, I want to keep things as crude as possible. From what I have read I have so mucg fun to look forward too, like aligning everything, tramming and smashing through a collection of cutters. Can't tear mt hair out anymore coz I'm bald.
  1. BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
    By njhussey in forum DIY Router Build Logs
    Last Post: 13-04-2020, 05:03 PM
  2. BUILD LOG: First Build-Steel Gantry CNC - Comments on design wanted
    By olaff in forum DIY Router Build Logs
    Last Post: 06-12-2015, 08:34 PM
  3. New build – input/comments appreciated
    By ngundtoft in forum Gantry/Router Machines & Building
    Last Post: 05-10-2015, 11:38 AM
  4. My new, and first build....comments greatfully received
  5. noob first build
    By japcarmaniac in forum Gantry/Router Machines & Building
    Last Post: 13-03-2012, 11:56 AM
