  1. #21
    Lives in East Lothian, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    Quote Originally Posted by D-man View Post
    Is this what you mean mate?
    Use the CM terminal, not the -
    However that wouldn't explain why the spindle isn't spinning.
    What's the acceleration value set to? F0.10
  2. #22
    My Bad, i will go to CM.
    F0.10 - 0.8
    F0.11 - 0.9
    next to these it says that the parameter is related to the inverter model
  3. #23
    What would be the best way to wire that up then, you saying I need a relay?
    Depends on Eding outputs and I've never used it so can't tell you. However using relay removes any posibilty of damage and is simple.
    quick look at manual shows it's possible to use method I suggested see sec 9.2 it shows simple wiring setup.
    If not got relay then for test just setup the 0-10V side and simply short wire between FWD and CM to see if spindle comes to life at the speed set in eding.
  4. #24
    Its also worth mentioning that if i unlink CM & FWD the VFD shuts down (Fan goes off etc)
  5. #25
    Does the display stay on?
  6. #26
    Here is a video of what happens
    https://youtu.be/yVzY6sCKhOw
    Sent from my iPhone using Tapatalk Pro
  7. #27
    That's normal.
  8. #28
    what is set in accel setting param f0.10 set it to high number to test try 20
  9. #29
    That's normal.
    Oh really? So when spindle fires up the fan etc will pop on?
  10. #30
    So wire up as per picture and change parameters you mentioned and also accel ?
  1. FOR SALE: Eding cnc controller
    Last Post: 01-08-2016, 03:31 PM
  2. Eding cnc
    By Ben-bee in forum CAD & CAM Software
    Last Post: 17-05-2016, 08:48 PM
  3. Setting ADTECH servos with Eding CNC software steps/AppUnit
    By D-man in forum Stepper & Servo Motors
    Last Post: 24-04-2016, 02:50 PM
  4. CONVERSION: Sieg X2 super with ball screws and Eding CNC controle
    By Soren DK in forum Conversion Build Logs
    Last Post: 11-04-2016, 08:40 PM
  5. Eding CPU5A4E controller and Siemens G110 VFD.
    By calgone in forum EdingCNC (CPU5, CPU5A)
    Last Post: 06-02-2015, 11:31 PM
