looking at the breakout boards inputs
Name:	bob opto isolated input.jpg
when the limit switch is closed, the EL817 opto isolator's NPN transistor will ground the printer ports input pin
the breakout board does not have any pull up resistors to ensure a printer port input is at a valid logic high when the limit switch is open
this can be a problem with PC's or laptops with 3.3V printer ports
John
