Page 24 of 50 FirstFirst ... 14222324252634 ... LastLast
  1. #231
    Chaz's Avatar
    Ok, cleaned up a bit, removed the reference table, mounted the main table and did a quick test fit of the Z Axis bottom part.
    The naked machine
    Some bits on it
    Z axis, ballscrew is just 'hanging' onto the overhang, not mounted. The Z axis needs some of the holes to be drilled all the way through and I need to find the location of the bottom carts. I did not have the measurement at hand when I machined the holes on the larger mill. As these are not threaded, I have a bit of margin for error.
  2. The Following User Says Thank You to Chaz For This Useful Post:
  3. #232
    That's looking a bit of a beast Chaz!
    Neil...
    Build log...here
  4. The Following 2 Users Say Thank You to njhussey For This Useful Post:
  5. #233
    Not sure if anyone is actually reading this thread anymore or not.
    Ooo you do like to jest!
  6. The Following User Says Thank You to Lee Roberts For This Useful Post:
  7. #234
    The naked machine
    Some bits on it
    I have to say I think your 3d printer might be a bit over engineered ;)
    That is a work of art ;)
  8. The Following User Says Thank You to Desertboy For This Useful Post:
  9. #235
    Chaz's Avatar
    Can anyone recommend me a nice simple watercooling solution for the 4KW Spindle.
    I had considered something like:-
    6mm fish tank tubing (size to be confirmed)
    Small fish tank pump
    Some form of container that allows the heat to leave the cooling cylinder.
    Ive seen some elegant solutions that use a CPU type cooler for a closed loop system, I am all ears ...
    Something like this (With fans stuck on it) would work well
    http://www.ebay.co.uk/itm/Baxi-105HE...UAAOSwA3dYPbSU
    Simply splice the radiator into the return.
  11. #237
    Chaz's Avatar
    Thanks. Certainly an option.
    I like this too, not sure how adequate it would be on a 4KW Spindle.
    https://www.youtube.com/watch?v=2OZCviK0msg
  12. #238
    I would worry that's underpowered but I also read you don't need a lot as the spindle are pretty efficient and don't make much waste heat. I'm going to use a 2.2kw spindle for maybe up to 10 hours per day 5 days a week I'm hoping a 200l barrel will be enough on it's own but if need be I'll use one of those heat exchangers I linked to I can get them much cheaper than that link from scrap yard friend so if you ever want one just PM me and I'll sort it out.
    I'm only going to use a maxijet pump (Aquarium style) but it'll be fine as long as the head height is enough (Which it is 2m's) but will need to reduce it for the spindle (13mm standard hose pipe on pump)
    The heat exchangers are 25mm pipe compatible
    These fans are pretty quiet and pump a lot of air also cheap!
    http://www.ebay.co.uk/itm/4-5-6-Bath.../261741641853?
    Just drill some holes in the fan casing and cable tie it to the radiator it's probably best the blow through the radiator but even if you suck I bet it would work great.
    You can fit 2 5" on the heat exchangers but 1 6" would be fine on it's own.
  13. #239
    Chaz's Avatar
    It seems most get away with 20 litres or less. Your 200 will be a massive overkill.
  14. The Following User Says Thank You to Chaz For This Useful Post:
  15. #240
    Ha ha ha now I take that as compliment from the man who's building his cnc machine from concrete and called it after either a norse god with a big hammer or the god of war lol.
    I have the space and the waterbutt so I figured why not ;)
