Thread: big budget cnc
    I know its also so close to me i could reach out and touch it, would be prefect project for me.
    If I wasn't so skint right now I would be buying this today ;)
    At prices like that it's not worth building an 8*4 I'd just buy one I have no doubt £1k and you can get that working and £2k and you can get working like new.
  2. Quote Originally Posted by Desertboy View Post
    I don't think its 8x4 its 3mtr x 2mtr bed so probably bigger still.
    I always think of these as 8*4 machines lol as that's what I mostly would use it for but the ability to do 10*5 would be very useful but only occasionally. If i do build my own I will build it to have a workspace of 3m*1.6m because you never know when you need those extra inches ;) Space is not an issue to me at the moment within reason I could fit 3 of these machines in ;)
    This machine would be spot on for what I want, I would then convert what I'm building now into an aluminium machine for cutting molds for vac forming and use the big one for wood only.
    the frame could i make it out of 50x50x3 mm or do i need to use bigger and heaver steel?
    i found this shop in holland i think the price is ok because i need supported rails of 3 meter long
    https://www.hardware-cnc.nl/en/shop/...ted-round-rail
  5. Quote Originally Posted by pet30 View Post
    You need to draw this up in Cad otherwise you will waste a lot on money quickly. What do you mean by "the frame" its hard for people to advise you without the CAD drawing.
    with frame i mean the base of the machine,
    i don't have cad program just sketchup i am a woodworker so for drawing kitchens etc thats good enough but i can draw very accurate in sketchup
  7. Quote Originally Posted by pet30 View Post
    At some point you will need CAD and CAM Fusion360 is good and free
    I know people love Fusion but cloud computing is about as secure as my Vauxhall Nova was (Was stolen 5 times lol)
    if you're data has no financial potential then use fusion if you data is valuable avoid clouds.
    My bank has been hacked twice in 6 years and virgin media last week, I have no faith in secure cloud computing at all.
    I know it's time to upgrade my cad so going to buy this package I think
    http://www.cadandgraphics.com/tupro2...Fee77QodVWkGUw
    Seems very good value for a semi pro workshop solution.
  9. Quote Originally Posted by pet30 View Post
    Anyway getting back on track with your build. I would start with the design of router bed first and then decide what you need to stand it on. Or build it all in one piece. In my opinion 50x50x3 is not strong enough for what you are trying to achieve
    2 years ago I had to build a punching machine (Hydraulic) for plastic I built it from 3mm box section AND it's not strong enough I have to run it about 1/4 the speed I built it to run to get decent results and I'm punching Polyprop. Any faster and the holes are not accurate! I heat the punchs to 230c as well to reduce stresses using nozzle heaters from injection moulding machines.
    I would think a minimum of 7mm would be needed if I wanted to make a steel router.
    I was shocked the stresses of punching plastic the aluminium casting we made wasn't strong enough to resist the forces and we had to recast in steel and on the first attempt the steel shrunk too much so we had to recast and grind to fit.
    If I had a cnc machine then would have been a lot more fun lol.
  1. Budget Power Drawbar
    By needleworks in forum Milling Machines, Builds & Conversions
    Last Post: 17-12-2015, 11:36 AM
  2. BUILD LOG: My Budget CNC Router
    By Nealieboyee in forum DIY Router Build Logs
    Last Post: 14-11-2012, 12:57 PM
  3. CONVERSION: X2 conversion on a budget!
    By craigrobbo in forum Conversion Build Logs
    Last Post: 30-10-2012, 05:00 PM
  4. Which spindle with a £200 budget?
    By fasteddy in forum Marketplace Discussion
    Last Post: 29-06-2010, 11:51 AM
