    Very nice jig Andy, this will eliminate the mishalighned side dots, cool!
    Its Chris, but thanks - I'll add the CAD to the Tele model download at some point as its a useful bit of kit for any 25.5" scale length neck.
    OK Andy that you are actually Chris... Lol, you are welcome!
    Nice work Chris. Once you have convinced yourself to put time into a jig to make a better job of it, it is always satisfying to put it use.
    For a long time now I've not used a centre drill prior to a 3mm twist drill and found it holds an accurate position on the hole. For large bits I will centre drill though.
    Did you need all that coolant for that job? I'll happily peck drill multiple 3mm holes with just an occasional dab on the drill bit from a brush.
    Otherwise nice work, progressing well.
    Yeah the coolant was a bit over the top - one of the things on my to do list is sort out a decent tap system for that.
    Better late than never but guitars are something I'm very interested in so I will start to follow this thread once I've caught up on the reading.
    P.S Where are the project files ? will they open in Rhino ?
    Edit: I think I'm correct in saying that the project files are accessed through Fusion360, in which case I won't be getting to them.
    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Welcome back Eddy long time no see
  8. The Following User Says Thank You to Clive S For This Useful Post:
  9. #8
    Hi Eddy - yes they are in Fusion 360 - the f3d files are also linked in my drop box on the CAM/cut out video,
    Any particular reason for not using Fusion?
  1. FOR SALE: CNC project
    By amxen in forum Items For Sale
    Last Post: 20-12-2015, 09:19 PM
  2. NEW MEMBER: Hello My CNC UK community
    By Xavi in forum New Member Introductions
    Last Post: 30-11-2015, 09:01 PM
  3. Community Shed
    By Musht in forum General Discussion
    Last Post: 06-10-2013, 12:15 PM
  4. Central South Community
    By Leadhead in forum General Discussion
    Last Post: 26-09-2011, 02:50 AM
