Page 3 of 3 FirstFirst 123
  1. #21
    What software was supplied with the machine?
    Was it a download, or was it supplied on a disk?
    The reason I'm asking, is if we can see what software/files you have, we'll be able to give more precise help, which should get you up and running quicker.
    Hi m_c The software came in disk is grbl 0.8.
  2. #22
    I was going by the link posted previously. I don't see any reason why a newer than 0.9 version wouldn't work unless there's something specific about the configuration, but see my previous post (that I made while you were most likely typing this reply!) about what software/files you have.
    I am sorry m_c I completely missed your this post. I came back from work and was tired as hell. Sorry 😞
    Disk came with kit and it contains grbl 0.8
    I have tried reinstalling it and installing it back on but still no luck so far.
  3. #23
    Lives in East Lothian, United Kingdom. Last Activity: 7 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    It would be helpful to see what's on the disk, as I'd hope it would contain a configuration file.
    How big (in MB!) is everything on the disk? Would it be possible to add all the files on the disk to a ZIP, and upload it somewhere?
    Ultimately you'll need to follow these instructions - https://github.com/gnea/grbl/wiki/Compiling-Grbl
    And then to test if it's successfully flashed to the board, open the terminal within the Arduino software, type and send '$' to see if you get a response as per - https://github.com/gnea/grbl/wiki/Grbl-v1.1-Commands
  4. #24
    Can it flash the arduino?
    http://blog.protoneer.co.nz/quick-gr...e-interpreter/
    If you follow this guide make sure you change the device settings that says mega to 328p (Might be listed as nano, think Uno works fine to)
  5. #25
    Hi m_c please give me your email and I will send you the zip format of disk. Thank you for your help buddy
  6. #26
    Thank you desertboy for the link. I am at work Will try that when I get home buddy.
  7. #27
    Did you get chance to check email m_c? I sent you earlier on.
  8. #28
    Yes, I got it.
    I'm on late shift this week, so only just got home.
    There's nothing in that archive that relates to the actual programming of the board, however it all references using version 0.9. Given everything references 0.9, it's probably wise to try reflashing 0.9.
    Try following the guide at the top of this page - https://github.com/grbl/grbl/wiki/Compiling-Grbl
    Download the grbl 0.9 files via this link - https://github.com/grbl/grbl/archive/master.zip
    And the main Arduino IDE software at https://www.arduino.cc/download_hand....3-windows.exe
    Let us know how you get on following that guide. And if you manage to establish any kind of communication with the board.
  1. What desktop cnc
    By fbiiburton in forum Gantry/Router Machines & Building
    Last Post: 28-08-2015, 04:10 PM
  2. 1605/1610 have they sent the wrong ones?
    By kingcreaky in forum Lead Screws, Nuts & Supports
    Last Post: 30-07-2013, 09:22 PM
  3. Desktop cnc, HELP
    By Walkz69 in forum Machine Discussion
    Last Post: 25-05-2013, 11:30 AM
  4. CNC Desktop Lathe
    By yadu in forum General Discussion
    Last Post: 16-01-2011, 11:07 AM
  5. Stiff 1610 ballscrews, need help.... asap.
    By ccmarco in forum Lead Screws, Nuts & Supports
    Last Post: 05-12-2010, 10:01 AM
