  1. #3
    What size tool, and how many flutes?
    What feed and speed did you use?
    Try 4-5m/min at 15,000 rpm.
    Hi Gerry,
    Thanks for reply. I was using a single flute spiral bit. 4mm dia and 12mm cut length. Spindle set at 'No 6', which i would take to be about 26,000rpm
    I'll need to get back to you about the exact feeds and speeds tomorrow. I set the feed rate in Aspire to 80mm/s in 2mm passes but of course this doesnt necessarily relate to the actual rate, which i'll work out tomorrow in Mach3.
    I did notice that it was rounding corners again so that'll need a tweak in motor tuning for wood. Currently settings are for foamboard carving.
  1. Help with speeds/feeds please?
    By examorph in forum Tool & Tooling Technology
    Last Post: 29-01-2017, 01:54 PM
  2. Speeds and feeds
    By eurikain in forum Workshop & Equipment
    Last Post: 26-03-2016, 06:00 PM
  3. Feeds and speeds software?
    By Leadhead in forum Computer Software
    Last Post: 31-10-2015, 09:34 PM
  4. Feeds and speeds
    By dudz in forum Tool & Tooling Technology
    Last Post: 26-08-2013, 11:42 AM
  5. Speeds and Feeds
    By Web Goblin in forum Tool & Tooling Technology
    Last Post: 20-09-2012, 01:38 PM
