    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I've not posted here a lot as I've only just started to learn a machine I bought back in June. Alas. at work I'm a heidenhan guy, but have worked with fanuc up until a decade ago. My machine uses Mach 3 and last night was the 1st time I cut metal. When I shut the program down, it asked me to save fixture data, which I assumed was the datums I had set on my job. Upon firing up today, it had lost position, so I had to reset them, any ideas why?
    Did you re home the machine on switch on first.
    Did you re home the re machine on switch on first.
    Hi Clive
    Y'know, I don't actually remember for sure. Although thinking about it now, I think I did reference it, yes. then watched in dismay as the readout changed, lol.
    RC cars
    RC helicopters
    Motorbikes
    Renovating an entire house
    Twatter: @CrazyLThirteen
    Insta: CrazyLThirteen
    Have a look at this Screenset; http://www.thecncwoodworker.com/2010.html
    I find it makes setting zero and using fixtures so much easier.
    Ta EddyCurrent
    I'll have to find out what version I'm running as I have no idea.
    RC cars
    RC helicopters
    Motorbikes
    To use comp in a circle like that, you need a lead in and lead out move. And different versions of Mach3 may require different lead in moves, as the comp was changed at one point.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. NEW MEMBER: Hi all, Ive got a plan, hopefully its a good one!
    By Benja in forum New Member Introductions
    Last Post: 25-06-2016, 12:58 PM
  2. A Cunning Plan For Accurate Homing With Mach 3?
    Last Post: 04-04-2016, 01:48 PM
  3. NEW MEMBER: Designer with a plan looking for advice
    By bigstu67 in forum New Member Introductions
    Last Post: 10-10-2012, 06:04 PM
  4. Cutting out a circle
    By Martin Paul in forum Machine Discussion
    Last Post: 19-04-2011, 12:58 AM
  5. So... what do you plan to do over the hols?
    Last Post: 23-12-2008, 09:03 PM
