Thread: Rotating Ballnut - design ideas
17-10-2017 #11
Remember that changing out a belt is no small project with the rotating nut design. So durability of a belt should be a big concern because of the downtime and hassle of disassembling everything in order to change out the belt. The whole ballscrew must be uninstalled to change a belt. No small task regardless of the size of the table.
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
