17-10-2017 #8
So I just used the probe and by hand found the center of one of the button holes in my case.
Was then able to chamfer the edges.
Not bad, not great. Was a hair out on the Y. X was perfect.
I just added 0.025mm to the Y and it is near perfect.
So Zeeflyboy your method works... :p
The real test would be machining around my part top and bottom now with out much, if any step in the surface finish once flipped and had the same operation done.
I guess the best way to do the flip is to leave 0.0something on the bottom of my stock and then flip, then remove that last 0.0something and chamfer...?
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
