Page 12 of 14 FirstFirst ... 21011121314 LastLast
  1. #111
    Nice one both you and Clive tested my spindle today with an ammeter and it's obviously pin 4 is not connected to anything ;)
    Will do as Clive suggested, were the top bolts hard to undo? I tried and felt some resistance like I have some loctite to break didn't want to push it until I asked had a nightmare rounding off A2's next time I build I will only use A2's were needed and stick to proper bolts if appropriate.
    I had to crack them, think there was some thread lock on the bottom of mine, i one exactly as Clive suggested. However still cant seem to get the spindle going - have not tried today however; might switch it back to manual configuration and run it directly from the VFD just to make sure that everything is wired correctly.
    It is usual to have the Z showing -ve going down so +ve and home would be at the top. The other two are personal choice.
    Re the Z only moving in one direction check the (dir) on the driver and make sure it is changing sense ie 5v and 0v
    Ok, well i guess it makes sense to change the X & Y to follow suit (Move Negative AWAY from the Home Position). At least then they are all the same and i can't confuse myself - which is very likely.
    Roger Roger - Will check that thanks Clive.
    Alex
  2. #112
    The machine looks very good.
    I am sure that with the help from all the expert guys here soon your cnc will run properly, carry on!
  3. The Following User Says Thank You to Nickhofen For This Useful Post:
  4. #113
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    If it was me I would keep the x and y going +ve away from the home switch. but still have the Z going down -ve as it is easier to read the gcode
  5. #114
    However, it is possible to have (0,0) in, say, the "bottom left" corner, which tends to be natural when you are standing in front of the machine, but have the home position in the top right corner and set the home position to the max value of travel. This gets the tool out of the way when you home. Or you can have each axis home at min or max. It's a question of choice. It's easy enough to configure Mach3 for each situation.
  6. The Following User Says Thank You to Neale For This Useful Post:
  7. #115
    Thanks guys i will have a think about it.
    Alex
  8. Hi Everyone,
    I'm glad someone is taking the time to elaborate on my design. ;)
    Although not much use to you now, I've been meaning to make the CAD files available for others to use, perhaps I will get onto that this week.
    I'm interested in seeing how your machine performs with 10 mm pitch screws. I used 1605 screws and have found them perfectly fine for my requirements. I've seen others online stating that 5 mm pitch screws are too slow and I fail to understood this statement. A machine this size which isn't used for production purposes I didn't see the need to maximise rapid speed. It's fast enough as it is! Perhaps a full size machine would require more speed, but then i'd probably move to rack and pinion anyway.
    I too prefer "home" the machine to the back right hand corner, this means that the gantry is at the back and out of the way after initial startup, ready for me to load a sheet of material onto the bed. I have the axis set up as X from left to right (gantry) and Y (dual motor drive) front to back when standing in front of the machine. Therefore my homing position is X+,Y+,Z+.
    I look forward to seeing some test cut footage on this machine!
    Jeremy
  9. #117
    Quote Originally Posted by Jerm View Post
    Hi Everyone,
    Jeremy
    Hi Jeremy! I hope you are well, i have been meaning to send you some updates on the build since we last spoke. Cad files would be great to a lot of people i think, a lot of people on the Facebook groups have asked - i just don't seem to have time to compile them neatly with a BOM right now.
    I have made a lot of progress yesterday and today, i have finished wiring the machine now (almost, but i'm leaving Max Limit switches off for now, the loom is there if i want to use it in the future). I added a Ferrite ring to the Spindle Cable where it exits the VFD enclosure & also at the other end where it wires into the Marine Connector Socket, i hope this helps keep inference down - i have also grounded the CY cable correctly (i think., I also just need to add an E-Stop to the controller.
    I got the Spindle working and also got it fully operational from the DDCSV1.1 controller. The Huanyang VFD is slightly strange, it requires you to daisy chain / common ground the DCM & ACM terminals (Analogue & Digital Control Signal Grounds), which does not make any sense to me. I'm not sure what the Chinese logic behind it is however it wasted an hour or two figuring it out but now works fine.
    Also got the Coolant Drum (An old & cleaned out 20 Litre Lacquer Tin), setup with the pump in it - which all seems to be working nicely with no leaks. If the Drum is 20 Litres, would this be a sufficient volume to passively cool itself? Should any type of Antifreeze / Coolant be added or replace the water to improve performance, help cooling, prevent corrosion in the Spindle Water Jacket?
    Next on the list is to try and wrap my head around SolidCAM, creating a Post Processor for it & getting some test programs run. Also at the point now where i need to look at getting the aluminium plates sorted.
    Alex
  10. #118
    The reason for separate digital and analogue grounds is that sometimes, for example, the BOB or motion controller will have separate power supplies for digital and analogue outputs and this allows you to keep them isolated. Not always needed but essential in some situations. Not as silly as it might look at first sight, but frustrating when the Chinglish manual doesn't really help!
  11. #119
    Ah that makes sense, another thing i found strange was i could not see anywhere in the Huanyang manual that stated what kind of signal the FOR input was expecting, so i also wasted another hour or so on that whilst trying to figure out the ACM / DCM grounding.
    Alex
  12. #120
    Wait a minute here... You got manuals for your stuff??? :D
  1. The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
    By Husky in forum Generic Chinese Spindles
    Last Post: 22-01-2021, 06:54 PM
  2. NEW MEMBER: new member building a cnc router
  3. Building a plasma table, need advice.
    By superclarkey in forum Plasma Table Machines
    Last Post: 20-09-2016, 04:57 PM
  4. NEW MEMBER: Newbie seeking CNC info for guitar building
    By rusty999 in forum New Member Introductions
    Last Post: 15-01-2016, 02:26 PM
  5. Building a hybrid CNC mill. Need advice and recommendations
