	11-12-2009 #1Ok ordered the new parts last week inc new power supply can't wait
 to get started
	11-12-2009 #2
	11-12-2009 #3Just as you advised:-
 and thanks for all your help for pointing me in the right direction;
 system 4 main board,
 two 2.5a bipolar stepper motor drive cards,
 a spindle control module card,
 and power supply
 I'm looking forward to the rewire and getting it up and running.
	12-12-2009 #4
	18-12-2009 #5Well the parts arrived yesterday I have been hard at it
 the photos are on there way everythings gettin there
 just a few things am stuck with stepper motor wires each has 8
 which do i use for the drive cards
 orange and white/ black and white both pair joined
 red and white/yellow and white both pair joined
 black,red,orange,yellow.
 also do I use the potentiometer wires black,red,blue
 and below/ connected to the spindle motor there is an inductor
 there are 4 wires here two large black,red the red runs into the inductor
 and two small wires pink/white.
 http://i60.photobucket.com/albums/h2...s/lathe001.jpg
 http://i60.photobucket.com/albums/h2...s/lathe003.jpg
 http://i60.photobucket.com/albums/h2...s/lathe012.jpg
 http://i60.photobucket.com/albums/h2...s/lathe014.jpg
 http://i60.photobucket.com/albums/h2...s/lathe017.jpg
 http://i60.photobucket.com/albums/h2...s/lathe019.jpg
 http://i60.photobucket.com/albums/h2...s/lathe020.jpg
 http://i60.photobucket.com/albums/h2...s/lathe021.jpg
 http://i60.photobucket.com/albums/h2...s/lathe023.jpg
	19-12-2009 #6I have looked every where for info on this lathe can't get much
 if anyone has a manual a copy would be most appreciated.
 scotty
	09-01-2010 #7Just a wee update; I managed to get hold of a connect 121 manual and a mach3 tut printed version and I have saved it to usb. also I now have a fully working cnc lathe. Woo Hoo! and a big thanks to Irving for helping me out with lots of much needed info. The motor control card was busted so I ordered a new one and now we are now up and running. I just need to learn how to draw in cad and which software to get. I think if I can get into the swing of things I will keep it. Failing that it's going back on the bay and hopefully i will get a manual one. Last edited by scotty; 09-01-2010 at 03:37 PM.
	09-01-2010 #8well done Scotty, and thansk for the thanks :)
 you can always drive the CNC lathe manually via MACH3... easier still with a pendant... here is a nice homebrew example but you can buy commercial ones...
  5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display PortBy LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM
  4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.By TommeyReed in forum Motor Drivers & ControllersReplies: 2Last Post: 06-03-2012, 06:01 PM
  NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis MillingBy LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM
  Y axis is making X axis stall...!!By fasteddy in forum Machine DiscussionReplies: 83Last Post: 24-10-2011, 12:19 PM
  Precision metal processing (3 axis, 5 axis, 7 axis) OEMBy 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
