Thread: Aluminium profile CNC
25-11-2017 #41
Hi Brice0
Could you post a link to Chai's store.
Regards
Mike
25-11-2017 #42
Here is the actual design
But I will add pulleys as you recommend, I could probably keep the same length to add pulley?
I was thinking to add something similar to the design of JoeHarris:
Hi mekanik, here is the link of Chai Store: www.ebay.fr/usr/linearmotionbearings2008
The Following User Says Thank You to BriceO For This Useful Post:
14-12-2017 #43
Does anyone has any experience with these HTD pulley? http://www.beltingonline.com/14-toot...14-5m-15f-7771
I think to use them for all axis, ratio 1:1.
14-12-2017 #44
14-12-2017 #45
Yep, used them a lot, good quality, no issues.
18-12-2017 #46
Thanks for your feedback!
18-12-2017 #47
Not read the whole thread but your initial design is incredibly similar to how I just built my router and I can say from experience don't fit the rails on the gantry that way! You lose too much travel.
I lost almost 28cm of Y travel because of how I built the Z axis at some point I will rebuild it so I only lose 15cm but luckily I built it oversized so I still 1.2m*0.7m which is enough to do what I want for now.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
18-12-2017 #48
18-12-2017 #49
Only the Z axis. I found a photo not a great shot I'll get you a better one later but you can see how much travel I lose mounting the Hiwin's forward facing on the gantry.
What I'm going to do at some point is remove the centre piece of extrusion on my gantry, strengthen the other 2 pieces up and mount the hiwin on top/bottom of them and sling the ballscrew between the 2 extrusions.Last edited by Desertboy; 18-12-2017 at 03:07 PM.
18-12-2017 #50http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
Aluminium profile cnc build
By valdis034 in forum Gantry/Router Machines & BuildingReplies: 84Last Post: 21-02-2023, 02:27 PM -
Aluminium Profile - ValuFrame?
By Tenson in forum Marketplace DiscussionReplies: 12Last Post: 24-09-2020, 07:21 PM -
Aluminium Profile
By amxen in forum Metalwork DiscussionReplies: 2Last Post: 13-08-2015, 07:37 PM -
eBay: KB Aluminium Profile Supplies
By KB Aluminium in forum Items On eBay UKReplies: 45Last Post: 20-05-2015, 03:46 PM -
Tapping Aluminium profile
By jonbabbz in forum Tool & Tooling TechnologyReplies: 3Last Post: 28-05-2012, 08:09 AM
