You can use an indexed 4th strategy rather than a rotary one, this will let you machine with the work fixed at multiple index angle intervals and access the entire part.
You can do this on a 3-axis system by having multiple copies of your part rotated in CAD to the required index angles and generating a path for each, paste the code together and manually add your index angles between blocks of code.
Ensure your clearance plane takes into account the rotating stock, it's easy to bust a cutter if the stock rotates and you haven't allowed for the corner height as it sweeps past! ;-)Last edited by magicniner; 26-12-2017 at 12:10 AM.
26-12-2017 #2
never knew this was possible thank you,
26-12-2017 #3
You do need to get your part on-axis in CAD so you can rotate it in CAD in a way which will match your stock rotation on your 4th axis, if you hit any walls give me a shout! ;-)
26-12-2017 #4
This is really interesting as I am looking to do the 4th axis indexing as well using Aspire V9, I have just built an indexer and constructed a stand alone control for it to be able to move from cnc to miller when needed.
I am not looking to carve a hand but how you would construct the full code would be very interesting.
Phill
26-12-2017 #5
i will keep posted for anyone else interested because if i can figure it out then anyone can as i have no experience at all but i do love a challenge.
The Following User Says Thank You to reefy86 For This Useful Post:
27-12-2017 #6
is it possible to preview a gcode made from deskproto?
28-12-2017 #7
Hi Reefy, I have been running with a demo of DeskProto today and it is producing a good Tap file but very large, so I have not got the tool-paths right yet some more testing required, I think it will do what you want and it's not too bad to learn.
Download a copy put an STL into it and watch the video for the settings you need.
Phill
28-12-2017 #8
28-12-2017 #9
eBay: ISEL Flatcom 40 1200mm x 800mm and Rotary 4th axis
By badgerman in forum Items On eBay UKReplies: 1Last Post: 07-02-2017, 01:37 PM -
4 axis rotary
By Blackrat in forum CAD & CAM SoftwareReplies: 3Last Post: 06-09-2015, 09:17 AM -
looking for a 5 axis cnc for largescale foam carving
By marbles in forum Marketplace DiscussionReplies: 2Last Post: 18-08-2015, 06:02 PM -
CNC Engraving Rotational Rotary Axis
By Fivetide in forum Machine DiscussionReplies: 4Last Post: 31-07-2015, 10:34 AM -
Sturdy Rotary Axis for CNC table
By Boyan Silyavski in forum Linear & Rotary MotionReplies: 7Last Post: 31-08-2014, 11:53 AM
