  1. #24
    Lives in Plymouth, United Kingdom. Last Activity: 13 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Pretty certain I have run into this on my Bridgeport conversion, IIRC if you jog the table while in the M6 loop it will fault with ePid error.
    Any idea how i find the "well documented" info :)
    Dave - take a look at this for starters. It has a couple of pointers to some general info on Mach3 internal architecture and at the bottom of the post a pointer to a pdf with a bit more specific info on the CSMIO problem. What it doesn't have is a "fix" as really there isn't a proper fix as such. However, I have found that .028 works fine (at least, I have had no problems with it on my machine) although it has a few other bugs which were fixed in later releases. I have a feeling that these were more lathe-related, though, so not something that worries me too much. I have seen another post that suggests version .022 as well.
    Maybe I overstated it a bit when I said "well-documented". The problem is well-documented in the sense that plenty of people have complained about it. In general, it shows up if you do any movement between an M6start and m6end. That rules out tool-height setting during a tool change, which is a bit of a bugger. The "solution" or work-around seems less well known but it does seem to work.
  2. The Following User Says Thank You to Neale For This Useful Post:
