Thread: Stock on facing
20-01-2018 #11
Your time creating paths would be normal if you follow industry conventions.
Top of Part should be the top of your part, your stock should be defined correctly within the software and your CAM can then see what is required for a facing cut on the top of the part, without you defining the depth of material to be removed, because it knows the depth of stock above the part. You just tell it the depth of cut you want to use with your cutter and the CAM will work out if it needs one or more passes.Last edited by magicniner; 20-01-2018 at 01:14 PM.
roundbar stock
By dfox1787 in forum VectricReplies: 4Last Post: 10-01-2018, 02:51 PM -
where to buy stock aluminium
By dfox1787 in forum Marketplace DiscussionReplies: 9Last Post: 27-12-2017, 11:27 PM -
Metal Stock Purchasing UK
By paul_m in forum Metalwork DiscussionReplies: 7Last Post: 25-05-2015, 04:42 PM -
RFQ: RFQ: Keyslot milling in alu round stock.
By Saracen in forum Projects, Jobs & RequestsReplies: 2Last Post: 05-09-2013, 09:42 AM -
Method for holding Stock
By Chaz in forum Machine DiscussionReplies: 4Last Post: 24-06-2013, 11:41 AM
